Running Pig Rich at Start up
Thanks for the Help guys....Scott big cams so it indexes you way up (this table has no
clue about RPM) same as if you were at 70kPa under
load. Shave back the cold enrichment at higher MAP
values. Doing this will also make the motor more
efficient at idle, lowering the MAP required to run
and improving things further.
Having a VE table that's also rich due to depressed
low-RPM pumping (from overlap) doesn't help any
either.
Fix the VE when hot and then the OLFA is what's
left hanging out, cold.
either.
1.67 1.48 1.33 1.27 1.21 1.14 1.06 1.04 1.08 1.07 1.05 1.03 1.02 1 1 1 1 1 1
1.62 1.48 1.33 1.27 1.21 1.14 1.07 1.05 1.08 1.07 1.06 1.04 1.03 1.01 1.01 1.01 1.01 1.01 1.01
1.62 1.5 1.33 1.27 1.21 1.14 1.07 1.05 1.13 1.11 1.07 1.05 1.04 1.02 1.02 1.02 1.02 1.02 1.02
1.62 1.52 1.34 1.27 1.21 1.15 1.08 1.07 1.14 1.14 1.07 1.05 1.04 1.02 1.02 1.02 1.02 1.02 1.02
1.65 1.54 1.35 1.28 1.22 1.16 1.1 1.09 1.14 1.14 1.08 1.06 1.04 1.03 1.03 1.03 1.03 1.03 1.03
1.67 1.56 1.37 1.29 1.23 1.17 1.15 1.12 1.14 1.14 1.08 1.06 1.04 1.04 1.04 1.04 1.04 1.04 1.04
1.67 1.56 1.39 1.32 1.26 1.2 1.17 1.15 1.14 1.14 1.08 1.06 1.06 1.06 1.06 1.06 1.06 1.06 1.06
1.67 1.58 1.41 1.33 1.27 1.21 1.19 1.16 1.14 1.14 1.08 1.06 1.06 1.06 1.06 1.06 1.06 1.06 1.06
1.69 1.58 1.42 1.34 1.28 1.24 1.21 1.18 1.14 1.14 1.08 1.08 1.08 1.08 1.08 1.08 1.08 1.08 1.08
1.69 1.6 1.44 1.35 1.29 1.25 1.23 1.2 1.15 1.14 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09
1.72 1.62 1.46 1.38 1.32 1.28 1.25 1.23 1.18 1.14 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11
1.72 1.62 1.46 1.38 1.33 1.3 1.28 1.25 1.18 1.14 1.12 1.12 1.12 1.12 1.12 1.12 1.12 1.12 1.12
1.75 1.62 1.47 1.4 1.34 1.3 1.28 1.26 1.18 1.14 1.13 1.13 1.13 1.13 1.13 1.13 1.13 1.13 1.13
What do you think? Thanks
a stocker might see a cold idle mixture commanded of
maybe 12:1 while a big cam car, maybe 11:1 at the
same temp just by that table column (let alone any
airflow inaccuracy).
That appears to be the same as my stock '02 tune.
On a T-Rex car I worked with, remotely, we ended up at
something like this:
1.67 1.48 1.3 1.15 1.1 1.06 1.05 1.04 1.03 1.02 1.01 1 1 1 1 1 1 1 1
1.69 1.49 1.31 1.16 1.11 1.07 1.06 1.05 1.04 1.03 1.02 1.01 1.01 1.01 1.01 1.01 1.01 1.01 1.01
1.7 1.51 1.33 1.17 1.12 1.08 1.07 1.06 1.05 1.04 1.03 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02
1.72 1.52 1.34 1.18 1.13 1.09 1.08 1.07 1.06 1.05 1.04 1.03 1.03 1.03 1.03 1.03 1.03 1.03 1.03
1.74 1.54 1.35 1.2 1.14 1.1 1.09 1.08 1.07 1.06 1.05 1.04 1.04 1.04 1.04 1.04 1.04 1.04 1.04
1.77 1.57 1.38 1.22 1.17 1.12 1.11 1.1 1.09 1.08 1.07 1.06 1.06 1.06 1.06 1.06 1.06 1.06 1.06
1.79 1.58 1.39 1.23 1.18 1.13 1.12 1.11 1.1 1.09 1.08 1.07 1.07 1.07 1.07 1.07 1.07 1.07 1.07
1.8 1.6 1.4 1.24 1.19 1.14 1.13 1.12 1.11 1.1 1.09 1.08 1.08 1.08 1.08 1.08 1.08 1.08 1.08
1.82 1.61 1.42 1.25 1.2 1.16 1.14 1.13 1.12 1.11 1.1 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09
1.85 1.64 1.44 1.28 1.22 1.18 1.17 1.15 1.14 1.13 1.12 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11
1.87 1.66 1.46 1.29 1.23 1.19 1.18 1.16 1.15 1.14 1.13 1.12 1.12 1.12 1.12 1.12 1.12 1.12 1.12
1.89 1.67 1.47 1.3 1.24 1.2 1.19 1.18 1.16 1.15 1.14 1.13 1.13 1.13 1.13 1.13 1.13 1.13 1.13
1.9 1.68 1.48 1.31 1.25 1.21 1.2 1.19 1.17 1.16 1.15 1.14 1.14 1.14 1.14 1.14 1.14 1.14 1.14
Not really gross changes, but brought his cold idle
commanded AFR back pretty much in line with a
stocker, given the idle MAP differences, at least at
more moderate temps; he was not being exposed
to temps below zero so we had no data / feedback
there, and we left those colums alone.
Peeling back the cold enrichment shouldn't bother
you much. If you found ping when cold you'd have
to make more adjustments but I think you'd have
to try pretty hard to get cold ping. You shouldn't
beat on it cold anyway, the way these things
rattle.
After Cold Start up my engine wasnt choking on fuel
Seems how I dont beat on it when cold,I was thinking of changing the Multiplier table to all numbers being 1.00 Will this be ok?Thanks!!Scott
of this table, in the X dimension, as your choke. You will
want some degree of cold enrichment I'm pretty sure.
But less oinking, probably better.
For anything above freezing I doubt you'd need to be richer
than 12:1 at idle. Though GM seems to have thought
otherwise. Where the wideband would come in handy is,
in separating the effects of the commanded AFR (FAM)
from this table, and the effects of other mods that might
compound the enrichment (specifically the VE table being
over-rich in effect). Cold start being open loop, can show
you both and the LM-1 would tell you whether it's all in
the OLFA table, or there's more to it.
