Iac counts
Did you adjust the idle set screw and do the relearn procedure?
https://ls1tech.com/forums/pcm-diagnostics-tuning/177230-stop-drilling-those-tbs-fix-stalling-without-computer-tuning.html
yes I did this that is why I am confused. The problem that I am having though is that the if I raise the screw up then the tps voltage goes above .60 so I have counts that are too high and voltage that would be to high.
If the Screw is taken out my voltage is at .57 is that not a little high for the blade to be closed all the way
yeah mine is at .61-.63 V, u need to let more air in that sucker. then reset the sensor
unplug the sensor, turn ignition on for about 30 sec, turn ignition off, plug sensor back in and turn ignition back on and log and see what it says. mine went from 2% down to 0% after doing this
Moderately Differentiated
https://ls1tech.com/forums/showthread.php?t=177230
You can do the tps reset thing but it only works up to a point. I found that point with my lowly 222 cam so he'll probably definately run into this with the trex cam. If you open the throttle body far enough, tps won't reset to zero any more and the car will think you're trying to rev the engine instead of idle. Once you get to that point you have to drill to get your iac counts down.
How do I reposition the Iac Sensor. I have had the screw as high as .67 and it still jumps all around. Then once it settles for a little bit if I rev the engine it trys to die it does not even rev up.
I am also having the problem when I am driving and I am coming to stop the car almost dies and goes as low as 400 and 500 RPMs. Sometimes it will die if I do not give it gas. Do you think this has to do with the Iac Count
