Tuning from in-dash PC "On-The-Fly"
Old Jul 23, 2005 | 01:21 AM
Frizzle Fry's Avatar
Question Tuning from in-dash PC "On-The-Fly"
I'll be mounting a touch screen PC in my dash for multi-media and wireless internet purposes. I was wondering If I could leave the OBDII permanently connected to the ECU and what on-the-fly tuning and/or logging capabilities this might give me. In other words, If you had an in-dash PC, what would you want it to do in regards to ECU duties, and what consideration might there be as far as EFIlive v. HPT in this application? BTW, emissions are not a concern
Thanks
Old Jul 23, 2005 | 02:38 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
A company in australia put together a pcm that has an ethernet port, allowing on the fly tuning. However, the idea was to do the on the fly tuning, save the program, then load it onto a regular pcm. Right now, there isn't any program to allow you to change programming with the engine running with the factory pcm.
Old Jul 23, 2005 | 03:33 AM
Holden LS1 Tonner's Avatar
is that RTLS1 (real time LS1) you are talking about ?
Old Jul 23, 2005 | 09:00 AM
horist's Avatar
^^^ not sure if that's what it's called, but it's the PCM w/the Ethernet port built in
Old Jul 23, 2005 | 09:26 AM
technical's Avatar
At the very least you could hook up the screen and a small computer that runs scanning/tuning software. You could definitely log data realtime. You would of course have to stop the engine to program the PCM...
Old Jul 24, 2005 | 05:25 PM
Thanks guys. I think the in-dash logging/flashing will be, if nothing else, a novelty.
Old Jul 24, 2005 | 06:15 PM
Tiger2o69's Avatar
Im in the middle of doing this. you can get a screen cheap on ebay.
Old Jul 24, 2005 | 10:07 PM
I have an all-in-one touch screen/PC made by Axiom. It'll be running XP. I might even run my airbag system from mine. It's just as matter of finding/writing the software for it. I have pretty good connections in this area, so I think it's doable. What functions do you plan to use yours for? BTW, nice avatar!
Old Jul 24, 2005 | 11:12 PM
gametech's Avatar
You have to be joking. You would really trust safety devices like airbags to microsoft software? Talk about your computer crashing!
Old Jul 24, 2005 | 11:13 PM
Black02SS's Avatar
I was under the impression he is talking about airbags for his truck. Not the actual airbag system in the car.
Old Jul 24, 2005 | 11:15 PM
gametech's Avatar
I hope so.
Old Jul 25, 2005 | 12:02 AM
Airbag suspension, yes. No safety airbags in a hotrod... That's what good brakes and 5-point harnesses are for.
Old Jul 25, 2005 | 12:28 AM
EFILive's Avatar
Restricted User
EFILive comes with a programmer's API to allow anyone who can write Windows software to interface with EFILive's OBDII Scan Tool.
Basically, you just make a few function calls to a dll (obdiiv7.dll) and all the OBDII data is available to your own application.
EFILive was designed that way exactly for the integration of devices that you are planning.
Alternatively just use the full EFILive Scan Tool. EFILive has a very customizable built in dashboard that (in the next release) can be almost maximised to the full PC screen.
Regards
Paul
Old Jul 25, 2005 | 12:50 AM
gametech's Avatar
I woudn't trust microsoft with my suspension, either.
Old Jul 25, 2005 | 09:08 AM
technical's Avatar
Alright we get it...you don't like Microsoft.
Old Jul 25, 2005 | 09:37 AM
slow's Avatar
There is no cost effective solution to this at this time, I looked into the real time from australia, but i could buy another car for what it costs.
Ryan
Old Jul 25, 2005 | 10:48 AM
Tiger2o69's Avatar
The main purpose for me doing it is so I dont have to carry the laptop around all the time and sit it in the seat and worry about plugging it into the inverter when the batter goes out ect..
Also it will be a lot easier to look down at the screen to see what going on instead of looking into the seat like I usually do. Its also a lot safer.
I have an older laptop that I plan on using and putting it somewhere out of the way. Probably under the seat would be the best place.. I have seen the smaller pc's for cars online but they arent as slim as the laptop. Im just going to remove the part that turns it off when you close the lid.
I also plan to use it for dvd's, wireless internet, navigation, and basic functions.
I originally wanted to buy the avicn1 and get it all connected w/ that but it doesnt look possible. Im still trying to figure out how to mount it tho.
Old Jul 25, 2005 | 10:51 AM
Tiger2o69's Avatar
I was over at a friends house and he just sold his honda and bought a cobra so he was removing the turbo and putting it back to stock. He was tuning using aem software and ecu. Everything was realtime and it was awesome. I couldnt believe that it just flashed it in as he made changes
Why cant they make this for our cars? It wasnt much more expensive than hptuners and it looked a lot cleaner. Did a lot more stuff as well.
Old Jul 25, 2005 | 06:14 PM
gametech's Avatar
If you swap in a fast or bs3 pcm, you can tune on the fly. You do have to work out some issues to make the factory gauge cluster work, though.
Old Jul 26, 2005 | 12:23 PM
I have a Porsche 996 cluster in a 1961 truck, so anything is possible Thanks for the input.
