IFR's for mototron 60# injectors??
Old 10-20-2005, 11:18 AM
ninobrn99's Avatar
Default IFR's for mototron 60# injectors??
what would the ifr's look like for these injectors??
Old 10-20-2005, 05:39 PM
ninobrn99's Avatar
anyone??
Old 10-20-2005, 05:48 PM
2xLS1's Avatar
69.28325412 69.71504837 70.14418464 70.5707114 70.99467569 71.41612314 71.83509806 72.25164345 72.6658011 73.07761161 73.48711443 73.89434793 74.29934942 74.70215521 75.10280062 75.50132005 75.89774699
Old 10-20-2005, 05:50 PM
ninobrn99's Avatar
thanks! may i ask how you came up with them? just trying to make sense of all the numbers...
Nino
Old 10-20-2005, 06:04 PM
2xLS1's Avatar
Download the injector.xls file mentioned in the stickies and it figures the values for you.
Old 10-20-2005, 06:06 PM
ninobrn99's Avatar
so all you changed was the injector size? i didnt know if i needed to change any of the other values is all. thanks!
RedHotSupra is gonna be pissed at me He personally emailed it to me
Old 10-20-2005, 06:11 PM
2xLS1's Avatar
They are rated 60# at 43.5psi so you have to enter the new pressure as 58psi and it does the rest.
Old 10-20-2005, 06:18 PM
ninobrn99's Avatar
58 psi is the FP at WOT correct?
Old 10-20-2005, 07:03 PM
RedHardSupra's Avatar
i'm not pissed, just disappointed, on these sort of questions i always argue with myself if i tell people do learn to do it proper themselves, or do i just post the answer because then you populate forums with answers, not flamewars. now that you saw the answer, go use the spreadsheet, n00b!
Old 10-20-2005, 07:04 PM
ninobrn99's Avatar
i will!! id of done it myself but like i said in the other post..i couldnt get you on aim i wasnt going to ask for the answer i was going to ask for direction. I want to learn, not be told. I was curious what the FP would be, then i could've figured it out.
Nino
Old 10-20-2005, 07:07 PM
that's also been posted. multiple times. by me. see, this is what i mean by 'populate with data, don't pollute with flaming'--if the RIGHT information was more popular than flamethreads, there was more more of a hit-to-miss ratio on the search button. damn kids, polluting the search pool...
Old 10-20-2005, 07:13 PM
LS1TECH Sponsor
foff667's Avatar
Nino
you couldve asked me when you im'd me too noob...what you think im not capable
Old 10-20-2005, 07:56 PM
ninobrn99's Avatar
my bad bill..i didnt mean it like that dont go trying to give me **** Ill try not to let it happen again!! PROMISE!
Old 10-20-2005, 08:03 PM
joecar's Avatar
That is the FP regardless of WOT unless your press. reg. is MAP referenced (connected to manifold vacuum).
Old 10-20-2005, 08:20 PM
ninobrn99's Avatar
i thought it was...
Old 10-22-2005, 01:32 PM
joecar's Avatar
i thought it was...
With a MAP referenced pressure regulator,
at WOT the FP is 58 + MAP (in psi),
and at WOT the MAP value is almost BARO.
the IFR table would be flat (not sloped),
and that doesn't seem to be what you have.
The standard (unreferenced) regulator just keeps
the FP constant at 58 psi regardless of MAP or WOT,
and the PCM uses the sloped IFR table to control flow.
Old 10-22-2005, 03:18 PM
MECHAM's Avatar
this reads
Code:
0kPA               5kPA          10kPA             15kPA              20kPA           25kPA         30kPA            35kPA          40kPA         45kPA           50kPA         54kPA            60kPA           65kPA           70kPA           75kPA         80kPA
just to clarify
the bigger the number going this way -> mean the injector is going to flow more fuel?
Old 10-23-2005, 06:17 AM
joecar's Avatar
Code:
0kPA          5kPA         ...  75kPA           80kPA
69.28325412  69.71504837  ...  75.50132005  75.89774699
Yes, that's correct, bigger number means bigger flow rate.
The kPa scale is BARO - MAP a.k.a. VAC (in kPa); WOT is on the LEFT (VAC = 0 kPa).
The flow rate of an injector is proportional to the pressure difference across the injector;
on one side is fuel absolute pressure (FAP), on other side is manifold absolute pressure (MAP);
FAP is: fuel rail gauge pressure (which is relative to BARO) plus BARO (to make it absolute).
Pressure difference across injector = FAP - MAP = FP + BARO - MAP (all units in kPa).
So, for example, say BARO is 100kPa (for easy numbers), and that at idle MAP is 33kPa;
AT WOT, MAP is 100kPa, so press. diff. is (FAP - 100).
At idle, MAP is 33kPa, so press. diff. is (FAP - 33).
You can see that (FAP - 100) is less than (FAP - 33).
so, IFR is less at WOT (FAP - 100) than at idle (FAP - 33).
i.e. vacuum (at idle) assists the injector flow rate, BARO (at WOT) impedes it.
This is why the IFR table slopes up to the right
(tells PCM what the injector can do as VAC varies).
LOL... we just had our dinner and it's after 4am, I better get some sleep.... zzzz
