Is OLFA table used for any normal operating conditions ?
when entering PE your car uses what ever value is the Highest..and if OLFA is commanding 1.17 and PE is onlt 1.13..then it uses the 1.17 value from the OLFA
again this is because not all vehicle OS's have a PE Multiplier based on ECT
p.s. sorry for the hijack
not safe...unless your PE multiplier vs ECT is Tuned in properly
and its not based on Fuel Trim cells...its based on MAP...
MAP of 80 does not necessarily mean PE
PE is enabled by MAP and Triggerd By TPS vs RPM
there is a reason for this table..why do you want to defeat this reason?
operation. PE/WOT is one open loop mode that is
accessible by pedal. If this table is the fattest then
it will be used at WOT. If something else overrides it
with heavier fueling then it will be ignored but this
table is your "bedrock" enrichment and should be
made like you meant to use it.
-Josh
Funny cause i was gonna post a question about this yesterday
