code number 121 ap/tp sensor?
Old Nov 8, 2005 | 05:18 PM
10secopcar's Avatar
Default code number 121 ap/tp sensor?
we put a brand new delco tps on the car. cleared the code with snap on. but it only sets the code when at the track in staging lanes. dont understand y it only does it there or anywhere. i have a hard time believing a delco sensor is bad. but things do happen. any help is appreciated
Old Nov 8, 2005 | 06:50 PM
HumpinSS's Avatar
what program are you using.
Old Nov 9, 2005 | 10:43 AM
10secopcar's Avatar
LS1 edit and using the snap on to clear the code
Old Nov 9, 2005 | 12:05 PM
HumpinSS's Avatar
under diagnostics is there a tps p0121 min and max map test. If so increase this value to 75 and 65
Old Nov 10, 2005 | 09:06 AM
10secopcar's Avatar
so set the min to 75 and the max to 65 or switch them? so this is just a test parameter?
Old Nov 10, 2005 | 09:47 AM
HumpinSS's Avatar
switch em and yes it is just a test parameter. Its the min and the max values the PCM uses to run the test TPS% vs engine rpm. With a cammed car they wont match anymore and you have to either desensitize the test (EFILive has tables for this) or change the test values (Edit and HPTuners)
Old Nov 11, 2005 | 11:58 AM
10secopcar's Avatar
is it possible that having the cutout open is affecting this in some way? and when i change it seems how its just a test aprameter it wont affect anything else correct
Old Nov 11, 2005 | 12:23 PM
HumpinSS's Avatar
cutout wont do anythign its just a test that is failing. its a tps vs rpm test.
Old Nov 12, 2005 | 08:41 AM
10secopcar's Avatar
thanks for the help man. goin to track tomorrow
Old Mar 27, 2008 | 12:06 PM
Black LS1 T/A's Avatar
Moderator
Why don't people come back and update the status on things such as this?
Old Mar 27, 2008 | 02:09 PM
foff667's Avatar
LS1TECH Sponsor
You can find a good amount of info on the P0121 code right on our forum
http://www.hptuners.com/forum/showthread.php?p=101510
Old Apr 22, 2009 | 05:02 PM
Moderator
Definitely gotta try this when I get back up and running. Supposed to get back in the game in a few weeks.
