How am i supposed to clean
Old Jan 1, 2006 | 01:55 PM
04BlackGmc's Avatar
Default How am i supposed to clean
The MAF when the screen is in the way where i really need to clean(Facing the filter and oncoming airflow)?
Old Jan 1, 2006 | 07:58 PM
TAQuickness's Avatar
electrical parts cleaner and q-tips work for most people
Old Jan 1, 2006 | 11:20 PM
04BlackGmc's Avatar
I mean how the hell are you supposed to reach around?
Old Jan 2, 2006 | 12:08 AM
2xLS1's Avatar
4 screws and the ends come off the center section.
edit - nevermind. I see you have a truck. not sure how those come apart.
Old Jan 2, 2006 | 11:24 AM
04BlackGmc's Avatar
It looks like it doesnt..
Old Jan 2, 2006 | 03:01 PM
jimmyblue's Avatar
Moderator
I'd say just hose it good, through the screen, and
let it drip. Some of those little channels are right
over the sense elements. I would not use any
mechanical implement, just the electrical cleaner.
Be sure you use a "dries clean" one, not one that
says it lubricates. Spray it until the runoff dries
clear on a piece of white paper. The first runoff
bit should be "interesting".
Old Jan 2, 2006 | 07:20 PM
aux_fast_cam's Avatar
spray with electrical contact cleaner
Old Jan 2, 2006 | 08:25 PM
wait4me's Avatar
The oil on Kn air filters is a major cause in alot of dirty maf sensors. Usually a test of pulling the maf off and see if the problem went away is a good way to check.
Trans values dont change unless something is wrong with a sensor or the pcm.
Old Jan 3, 2006 | 11:57 AM
04BlackGmc's Avatar
WEll i pulled it off and it looks silver and clean.So i guess no need to clean.
