Will closed loop command this?
Old Jan 9, 2006 | 05:06 PM
Pavetim's Avatar
Default Will closed loop command this?
I have most of my NON PE section of the VE table set to 14.7 but a portion set to 13.5AFR. When I go back to closed loop will the compter be able to maintain the 13.5 or is it too far off from the 14.7 to keep it there? And i'm using my PE table to command 12.5 so thats why I can't use it to get my 13.5. Thanks guys.
Old Jan 9, 2006 | 06:48 PM
wait4me's Avatar
The only way for you to do that would be to be in open loop and use the open loop table, or use efilive custom operating system 3 and it will give you a full resolution fuel table that will use strims and will command what ever you put in the table cells.
Old Jan 9, 2006 | 07:16 PM
Pavetim's Avatar
Well I have hptuners. I have my OLFA table set like this 20-55kpa is 14.7AFR, 60-75kpa is 13.5AFR, and 80-100 is 12.5 AFR. I want to use the PE table to get my 12.5 but want to use my trims to get the 13.5. Will hptuners let me do this?
Old Jan 9, 2006 | 07:33 PM
wait4me's Avatar
Basically no. When the pcm is in closed loop it has a setting for what it is commanding. which is only one value. 14.62973 ect.. So, anytime it is in closed loop that is what it wants. If the pcm enters a pe mode, or a open loop mode, then the values can be changed to what is commanded, It is not using o2 feedback at this time so it uses a calculation to get it to what it thinks it should be.
Old Jan 9, 2006 | 07:44 PM
chrisj6's Avatar
Does everyone use 14.63?? Mine has always been commanding 14.681 so i never changed it, to my understanding stoich was alwys 14.7??
Chris
Old Jan 9, 2006 | 07:53 PM
Pavetim's Avatar
other than pe is there any way to make it go into open loop at a specified time i.e. map value?
Old Jan 10, 2006 | 10:11 AM
ringram's Avatar
Yes you can set closed loop mode temp way high so it never goes in, but unless your ve is dialed in right and your maf (if connected also dialed in) you arnt going to be commanding anything useful.
You can also only use ect vs map and not rpm vs map. Plus the usual PE mode.
You are better off with a custom OS to do all this else you wont get exactly what you want. You will also definately want a wideband installed.
Old Jan 10, 2006 | 11:58 AM
MeentSS02's Avatar
Kleeborp the Moderator™
If you are feelin sporty, you can just say screw it and run full time open loop. It ain't as bad as you'd think
Old Jan 10, 2006 | 06:00 PM
Pavetim's Avatar
Thats what i'm most likey going to do is run open loop SD all the time. And yes I have a wideband. I'm starting to get the tune just trying to think of every option possible to see whats better.
Old Jan 11, 2006 | 12:03 PM
MeentSS02's Avatar
Yeah...I've been through most options, and just got tired of the problems with my O2 sensors. As of this morning, they are completely gone and the holes are plugged.
Old Jan 11, 2006 | 12:04 PM
MeentSS02's Avatar
BTW, what does your car look like in case I see you driving around?
Old Jan 12, 2006 | 07:28 PM
Pavetim's Avatar
It is a pewter 2002 WS6 with the SLP dual/dual. I usually go to the main gym on eglin during the weekend. I think I may have seen your car around but not too sure.
Old Jan 12, 2006 | 07:44 PM
Bill Bowling's Avatar
Talking
I am running Open Loop SD all the time for the past 5 months. Works great.
Bill
Old Jan 15, 2006 | 11:35 AM
ninobrn99's Avatar
Hey Bill, is running in OL as easy as setting your OLFA tables to whatever a/f you want? what else is involved?
Old Jan 15, 2006 | 05:20 PM
MeentSS02's Avatar
Yep...then tuning it that way
I really like it...I actually just took my narrow band O2s off my car completely and used plugs in the holes...talk about weight reduction
Old Jan 15, 2006 | 05:25 PM
ninobrn99's Avatar
i bet that was big time weight saving so you just set the olfa to whatever a/f and then tune ve and pe?
Old Jan 18, 2006 | 04:03 PM
Talking
I do not even use the OLFA table. I am running EFILive Custom OS 3. I do not use the PE table either. I have one table. It is the old OLFA but RPM/MAP and I just set the AFR in each cell to what I want. Check out this doc:
http://www.efilive.com/doc/Tutorials...20Tutorial.pdf
Bill
