Is LS1 Edit worth getting for a stock engine...
Remove CAGS
Get rid of your speed limiter
Adjust your speedometer
Raise your rev-limiter. (If your a gambling man <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> )
As far as HP goes, you could probably squeak out a few more ponies. BUT, there are better ways to spend your money if you are looking for HP.
www.carputing.com I think is the website where you can get them. I'd love to see a complete list of what it can do myself.
hPP3. it allows you to adjust fuel, timing ect.....to whatever you want . its not a set thing like hpp3 you can change the setting in most everything in the pcm to what you want.
You could use LS1Edit with a desktop, the cable is long enough, but a laptop is obviously the way to go.
on a 6sp car maybe, maybe not. it doesn't come with any preset power loders or anything like that, sure you can go in and change alot of stuff like timing and fuel mixture but do you know what to change it to. it will take some studing and some trial and error or someone that has done it helping you so you know what to do to the timing, also if you are doing the trial and error aproch, like adding timing and doing a run you would probably want some kine of scan tool like atap to see what is going on in there.
i have a truck with an auto and a few mods and for $550 it was a bargain, so far i have adjusted for larger injectors, shift points, rev limiter, speed limiter, raised idle, lowered shift down points, removed TM. and in the next week or so will be geting rid of the egr set up and the rear o2's
Yes it is well worth it if you have an A4. I have already picked up 2 mph and dropped nearly 2 tenths just from playing with the shifts and deleting TM.
Derrick
