Rate on 6.0L '01 injectors?
Performance Trucks Sponsor
anybody happen to have flow rates and any other pertinent information for these injectors? i need to scale correctly for my setup.
thanks,
allen
thanks,
allen
How about some injector flow rate info on 6.0 injectors? I have a set and would like to know how close they are to 5.7 2001 injectors?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Looks like the injector flow rate should be 3.12 in the PCM. This works out to be roughly 24.6#s. So compared to an 01 LS1 injector, they are 4 pounds smaller, not to mention that they are multec type instead of the bosche LS1 style.
if i fill the injector flow rate with all of the same value, won't that be wrong? doesn't it need to increase as kpa increases?
i'll try it though and see how it works.
are you saying the first value should be 3.12?
thanks for the info,
allen
allen
Farmtruc - are you using a truck intake and fuel system? If so, its a static number across the whole chart. If you are running a car intake and fuel system, then the value will be dynamic and you will need to adjust accordingly.
red53gmc - I opened a 2000 PCM with LS1 edit and pulled the 3.12 number out of the injector flow rate table. I have a set of those injectors right here - part number 25317628. I haven't opened an 01 year file to see if it has 3.18 in its table or not. Makes you wonder why the difference in flow rate if its supposed to be the same injector.
i opened up a 2002 file and the injector flow rate was at 3.18 opposed to the 3.12
i wonder why they did that, more HP/TQ?
my setup consists of:
01 LS1
01 6.0L truck intake/coils/harness
01 Z28 pcm
01 vette MAF
99-01 4L60E
I'm running something that requires more than the stock injectors were designed for. i wonder if i need to increase the WOT Power Enrichment?
i'll find out when i get my fan mounts done, haven't had much time.
i'll put 3.18's in there and see what it runs like.
thnaks,
allen (oops, you weren't supposed to know i'm Farmtruc <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> )
01 LS1
01 Z28 pcm
01 vette MAF
99-01 4L60E
thnaks,
