Mail order tune, where?
decided to have pcmforless tune it..and he found alot of things that were out of whack
Since you already own HP tuners.... spend the money you'd spend for a mailorder for a wideband (LC1 ~200 bux) O2 sensor... then any questions you have ask them here.... (if you don't have EIO , it's still more worth it to upgrade to EIO then buy a Wideband IMHO .... mail order tunes are guess work... or rather educated guess work based on similar base setups ... if every car behaved the same.... then mail orders would own.. unfortuanetly not every motor/setup is the same)
In the stickies there is a walkthrough on SD tuning (also in HP Tuners there's a walkthrough in the help file) ...
(not having access to a dyno isn't a problem... in order to do a full SD tune on a dyno you need either a mustang dyno or a dynojet w/the dynopacks ... you would have to load the engine and hold it at varous RPM/MAP values... I as well as many others prefer to do this on the street using real world loads and values)
