O2 Sensors .....
My O2s read 80mV above a wide band on the chassis dyno that I use to tune my car for WOT, so I just make an adjustment in my head (and I dont mean the cylinder head). With the wideband at 880mV my O2s read 960mV.
You can go out and buy 100 O2 sensors and you may find one that reads 880mV when the wideband says 880mV. But why bother. Also, our O2s are very dependent on the exhaust gas temerature.
I am not much help here.
Gary
I adjusted my PE table by 97% to try and get it closer to where it needs to be. Now I just need to Auto Tap it and see if it made a difference.
Thanks Doc!!!
Others use exhaust temp. Which is an okay method of determining a/f.
<strong>For more protection have a wideband and 8 egt sensors. That way you know cylinder to cylinder variations.
Gary</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was wondering about this today. I watch my O2s and one bank shows to be a little richer than the other. Your saying have 8 egt sensors. What good would that do? Is there any way to adjust each bank (or even better each injector) so each cylinder gets the exact amout of fuel it needs?
Chris
Gary
