who here can flow a MAF?
i will send you a my stock maf and my o1 zo6 maf and a maf translator.
i would like for each to be flowed by themselves, and then each with the maf translators set at full rich. the y scale for the frequency i would like to have plotted in steps identical to ls1 edit
the idea is to put the new scale into edit and push up my calibration range closer to 512 at 11250.
thoughts comments? i may even buy one of those overpriced granitellis to try and if it doesnt go higher than the maft ill just send it back..
thanks.
Can you lock a flow bench in at a given flow to get an accurate reading of the MAF output?
Then you could just put the numbers in excel and fit a curve to them.
ProM could probably do it for a small fee also.
John
http://www.roadraceengineering.com/newafc.htm
but this comming from a guy that has used an o scope like 3 times ever and never a flowbench..
adjusting the air fuel is not what im going for with this.. i want the stock computer to do that for me..
<strong>but this comming from a guy that has used an o scope like 3 times ever and never a flowbench..
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's 3 more times than me. <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> Check your email. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
Glenn
is just a 5V supply and a frequency counter.
Forget the 'scope, unless it's a newer fancy
one that'll give you a frequency measurement
off the waveform. The frequency counter is a
whole lot more direct. You can even get a
$89 DMM at Radio Shaft that has that function
now.
Hell, I'd like to get one of my spare MAFs
calibrated too, then I could make a flow
bench of my own. Pressure gauges are
everywhere, it's the flow value that's hard
to come by.
Anemometer - Just an example
http://www.testequipmentdepot.com/extech/pdf/451189.pdf
Is the MAF on the car powered up when the key is turned to the ON position?? If so then you could get a short MAF extension harness and plug it into the MAF in the "flowbench". Turn the key to ON and use atap to monitor the frequency output of the MAF(If that is an atap option??). If not use the DMM that jimmyblue talked about to monitor frequency.
The fans could be powered off a battery or AC/DC converter. The flow could be varied with a speed control on the fans or with the inline TB idea.
Just some ideas. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
