GM 85mm MAF
You will also need to reprogram the PCM for the MAF to read right with a non modified 85mm MAF. The stock calibration in the PCM for the 75mm unit is different.
steve
Otherwise it's "close enough" (accorfding to SLP). All
you need is a decent soldering iron and a tweezer or
needlenose pliers or just a bent piece of wire. Here is
the critter:
for decades cars ran without MAF sensors... there are still a few new cars that dont have them either... and almost every aftermarket setup is Speed density.
basicly if you know the pressure in the manifold (the MAP sensor) and you know the temp of the air (air temp sensor) and you know the VE of the engine, you can calculate how much air is going into that cylender that instant...
in otherwords, your car runs just fine with no MAF sensor...
i like SD... nomatter what my avatar says...
well its a choice, with pros and cons.
if you are a stock, or close to stock guy, with little or no tuning experience, and want to do a few boltons, SD isnt for you.... but if you're a guy that has a heavily modified motor, you tune everything yourself, and you will be doing things that let you use SD to your advantage, then gofor it...
personally, id NEVER spray a dry kit on a 85mm MAF.... ive had too many problems with them in the past.
just add a fuel line, fuel 'noid, and a nozzle... make it a wet shot infront of the throttlebody.
although, if you have someone whos done it before, and can tune you on a load dyno (or on a long open road) using a wideband.... then maybe.. but if you're not having a tuner with modified MAF dry nitrous experience go at it with a wideband, i woudlnt do it.. the risk seems too high for me.
again, thats my opinion.. its entirely possible to do safely, but the risk taken to tune it to that safe level makes me nervous... if you were my local friend, id try to talk you out of it, and into a wet shot or something else...
de-resistored SLP MAF, very recently. Go with it.
because the SLP MAF isnt "calibrated" to work with the stocker.... instead its modifed to be "close enough"
so you would either have to make your own working MAF table anyway, for the 85mm SLP... or take their mod out, and tune it like its a GM 85mm with the tables found all over this board...
most of the tables arnt identical, but they're all very similar, and some are closer then GM had stock with their tables.
out. This table has been good for me:
freq Hz 750 800 850 900 950 1000 1050 1100 1150 1200 1250 1300 1350 1400 1450 1500 1625 1750 1875 2000 2125 2250 2375 2500 2625 2750 2875 3000 3125 3250 3375 3500 3625 3750 3875 4000 4125 4250 4375 4500 4625 4750 4875 5000 5125 5250 5375 5500 5625 5750 5875 6000 6125 6250 6375 6500 6625 6750 6875 7000 7125 7250 7375 7500 7625 7750 7875 8000 8125 8250 8375 8500 8625 8750 8875 9000 9125 9250 9375 9500 9625 9750 9875 10000 10125 10250 10375 10500 10625 10750 10875 11000 11125 11250 11375 11500 11625 11750 11875 12000
flow gm/s 0.2 0.27 0.34 0.41 0.49 0.58 0.66 0.73 0.81 0.89 0.97 1.05 1.13 1.21 1.29 1.59 1.88 2.2 2.58 2.99 3.45 3.95 4.5 5.1 5.76 6.46 7.23 8.06 8.95 9.9 10.91 11.98 13.14 14.39 15.74 17.19 18.74 20.39 22.14 23.99 25.95 27.99 30.14 32.38 34.71 37.16 39.73 42.5 45.41 48.47 51.67 55.02 58.48 62.1 65.86 69.77 73.82 78.06 82.48 87.07 91.82 96.74 101.82 107.08 112.48 118.07 123.83 129.76 135.87 142.17 148.61 155.26 162.11 169.17 176.44 183.94 191.72 199.8 208.06 216.62 225.44 234.52 243.89 253.45 263.21 273.23 283.55 294.15 305.06 316.32 327.93 339.92 352.32 365.16 378.47 392.3 406.7 421.7 437.34 453.69
I started using the MAF table from a Corvette Z06, tuned my VE table correct in sd mode. I got a 5.7L ls1 Holden.
I used RHS's spreadsheet to calibrate the maf, found it was OK at hwy speeds, but getting 172 left/right bank rich errors around town below 80 kph, tried to tune it out.
Ended up using the 6 litre truck maf table & found my LTFT's weren't to far out.
