Why are my IAC counts always at 0???
So far, I have not seen my IAC count ever go off of 0, what could be my problem. My car seems to idle alright, but I am having problems lowering my idle. It wants to idle at like 825-850, I have tried lowering, but it just won't go....
I just did a heads/cam swap.
Your problem is that autotap is the worse piece of software ever made. Each revision they bring out has a fixes a problem and creates another. My v2.03 does the same thing, it is a known issue.
What kind of heads/cam? I've heard of certain solid cam setups having problems like this. They usually have really high ltrims on bank 2 also. I forget exactly what causes it but if I remember the post right it had something to do with shotty help during the install.
well first off...how are you lowering idle?? only way edit!! second..did you put the car in gear or rev up etc. when checking IAC counts?? Third maybe your IAC module is bad??
I am using Edit, to try and lower my idle, but it isn't working...
Shotty help, you ain't kidding, it took me an hour to get the dipstick back in with there help.... <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
then..(Ican't remember which way) turn it in or out a 1/2 turn and see what the iac reads then..if still 0 then go the other way the 1/2 turn..usually a 1/2 turn was about 15-20 points on iac count.
