Everyone with SD tune issue: VERY lean on starts after certain time delay.
Old 03-30-2006, 09:29 PM
  #41
white2001s10's Avatar
Originally Posted by Haans249
LOL, good luck getting your car to even run. It'll most likely rev super high if you unplug it.
Adrian
IAC position doesn't change when you unplug it.
I guess you have no idea how many people run every day with it unplugged.
Old 03-30-2006, 10:57 PM
  #42
WS6FirebirdTA00's Avatar
Originally Posted by white2001s10
Somebody unplug their IAC and see if that's what's causing it.
It would at least narrow down the problem.
nope, that wont be the issue at all
Old 03-31-2006, 12:36 AM
  #43
Are you comparing PW's to see if they are decreasing?
or do you think the lean is caused by extra air-flow?
Old 03-31-2006, 01:18 AM
  #44
i think the lean condition is caused by some ve multiplier i dont have access to. i set my iac motor to 25 steps, hot idle is 35 steps, and the car is still way lean on me. I just think its something weird going on where the car thinks incomming air is hotter from being heat soaked. i have ruled out IAT as a culprit as well.
Old 03-31-2006, 05:19 AM
  #45
ninobrn99's Avatar
would spark affect it at all? pulling some or adding in that area to see if anything changes? im sure its been mentioned, just didnt feel like reading all the posts :p
Old 03-31-2006, 08:27 AM
  #46
Kleeborp the Moderator™
MeentSS02's Avatar
Basically, what this comes down to is that people just aren't comprehending the problem. This isn't some random, always there issue. It only happens after the car has been off for a certain amount of time, and only for a certain amount of time after the car has been restarted (~3 minutes). The parameters listed earlier in this thread only last for a couple of seconds at most, as they decay by crankshaft/camshaft revolutions, not seconds.
We are seeing something that is affected by a timer of some sort that is only active in SD, but not with the MAF running.
It has nothing to do with timing, and nothing to do with startup airflow/fueling.
Old 03-31-2006, 08:34 AM
  #47
ninobrn99's Avatar
Mike has this been happening ever since you were in SD or after you went 1bar OL?
Old 03-31-2006, 08:38 AM
  #48
Moderator
jimmyblue's Avatar
I am wondering why any amount of IAC, idle airflow matters
to fueling. The air should still be attended by adequate fuel,
according to your commanded fual air multiplier. Do you see
this going way lean at the time, or is it that the mixture is
diverging from the commanded point? I think this is the nut
of it.
Old 03-31-2006, 08:41 AM
  #49
MeentSS02's Avatar
On a warm restart, my car goes about 1.0 points lean (AFR) for about the first 3 minutes or so of driving. After that, it goes right back to commanded (~14.8-ish).
Old 03-31-2006, 09:33 AM
  #50
i think a small change in airflow like Steve is seeing could be iac related because on start up the iac motor on my car at least is arond 70 steps and hot idle works down to 35, i can see that because it will change the airflow about a point
on my car it is so damn lean that this doesnt even matter. i mean i am anywhere from 3-6 point lean on start up. and yes this issue has always been there just couldnt figure it out until i had the wb
Old 03-31-2006, 09:35 AM
  #51
MeentSS02's Avatar
Any idea where to mess with that one? I've got my laptop here, and a semi-warm car out in the parking lot.
Old 03-31-2006, 11:31 AM
  #52
Moderator
jimmyblue's Avatar
But is it the commanded that's whacked, or the actual
diverging from it?
Wonder if IAT heat soak / discrepancy might be in the
mix. That is a time-varying component of the speed
density calculation and might take some time to get
in line with the in-taken air (or if it's just flapping, be
a variable error term decoupled from true air). The
timescale for IAT to come around to reality can be long
at low airflows. The air mass from air volume*pressure
needs temperature to calculate (PV=nRt, n being molar
mass, etc.).
Old 03-31-2006, 11:33 AM
  #53
iat has nothign to do with it either, ruled that one out as i had the iat up to like 110* when it was 70 out and the car ran fine and i can put the iat in a cup of ice while its running and it wont do anything.
Steve, its the start up airflow parameters there were mentioned earlier, like start up friction airflow.
Jimmy, i have a post on hpt with a log. commanded will be like 13.7:1 and actual shows like 16.8:1. commanded is where i want it and actual is way lean
Old 03-31-2006, 12:20 PM
  #54
MeentSS02's Avatar
That doesn't work either...I increased the decay of it, but if you look close, it decays per camshaft revolution, so it takes hardly any time for that to go away. I'm still showing the same symptoms.
Old 03-31-2006, 12:29 PM
  #55
TAQuickness's Avatar
Correct me if I'm wrong, but a leaner mix = hotter exhuast right?
EPA demands cat's start functioning as soon as possible right?
Car sits for a few minutes (3 or so) and even though the motor is still pretty warm, the cats have had time to cool significantly.
Seems like if there is a table missing, it might have something to do with cat light off.
dunno. just thinking out loud.
Old 03-31-2006, 12:44 PM
  #56
MeentSS02's Avatar
That makes the most sense of anything I've heard yet...but why doesn't it do it when the MAF is in?
Old 03-31-2006, 01:00 PM
  #57
could be part of the whole SD is a backup for the MAF thing. Say the MAF fails, you default to an SD tune, PCM leans you out on start up to light off the cats and heat up the NB's so you can limp to the dealer for a new MAF.
Again just speculating. I can make all kinds of **** work on paper.
Old 03-31-2006, 01:02 PM
  #58
MeentSS02's Avatar
Apparently, GM could too
Old 03-31-2006, 01:55 PM
  #59
Restricted User
98Z28CobraKiller's Avatar
I dont have a WBO2 but I am pretty sure that I am having the same problem. I am a complete noob to tuning and my first wack at this has been by dialing in an LS2 402 in a 98 Z28 M6. Talk about jumping into the deep end with 50 lb cement shoes.
I just think that I am having the same problem because I have the idle and the VE tables dialed in perfect and after I stop and shut the car off for like 15 min and then start it back up, it runs kinda rough for about 3 min or so and then it's good again.
Old 03-31-2006, 02:00 PM
  #60
MeentSS02's Avatar
Without a wideband, yeah, you really can't tell, but it sounds exactly like running too lean to me. Mine idles perfectly fine from 13.0:1 all the way up to about 16.0:1. Starts getting rough around 15.5 on up though...
I just hate that no one can figure this one out...
Quick Reply: Everyone with SD tune issue: VERY lean on starts after certain time delay.
