Help please 2-3 shift problem
Old Aug 10, 2006 | 02:14 PM
STALL UP's Avatar
Default Help please 2-3 shift problem
Has anyone found a fix for the 2-3 shift banging the rev limiter at WOT threw tunning. I have adjusted so much stuff I dont know what is what anymore. I have had three tranny shops tell me it must be tunning. and the gm scan tool is not showing a commanded shift.
02 z28 4L60e
3000 stall
procharger
3.73 gears
Old Aug 10, 2006 | 03:33 PM
wait4me's Avatar
Is it a tps problem?
Old Aug 10, 2006 | 06:07 PM
STALL UP's Avatar
no, tps is at 100 percent
Old Aug 10, 2006 | 06:24 PM
joecar's Avatar
Bring the both WOT RPM and WOT MPH down until you start getting the 2-3 shift.
Old Aug 10, 2006 | 06:34 PM
STALL UP's Avatar
wot mph is set at 70mph and rpm is at 6200 it will go to 6700 which is my fuel cut-off
Old Aug 10, 2006 | 07:29 PM
joecar's Avatar
Ok, you'll have to try an experiement...
Set WOT RPM to 5500 or even 5000 and see if it shifts, taking note of the MPH and RPM.
Might want to check this first:
make sure the WOT downshift MPH is below the WOT upshift MPH (say 10 below);
if it's not, then it will block the WOT upshift.
Also: have you set the gear ratio so that VSS is computed correctly...?
What tune package are you using, you might want to ask them about this.
Old Aug 10, 2006 | 07:54 PM
wait4me's Avatar
try moving the Wot Tps enable percentage down lower.
The question i was asking about was VOLTAGE not actual pcm percentage.
Does the car shift if you only bring tps to 95%
Old Aug 11, 2006 | 06:32 AM
STALL UP's Avatar
Yea I have tried the 5000 rmp shift speed it dont work, but I will check the down shift vs upshift when I get home. Gear ratio is set also, thanks
Old Aug 11, 2006 | 06:36 AM
STALL UP's Avatar
I can back off of it alittle and it will shift, I am not sure what the tps% is when it does it.
