'98 vs. '02 VE tables.
I added a FAST 90 and 1-7/8 headers to my car and it lost about .4 and 5mph.
It reads lean as hell at idle, yet smells like someone is pouring fuel in. I've read that the overlap in the cam can cause false AFR readings by the PCM, as well as leaks (which I haven't ruled out). The cam is Futral F14 (232/234 .598 112LSA).
It's also reading lean on the top end as well, but the O2 MV's are 900+. I'm consfused and need a little help. I can post the tune when I get home for you guys to take a look at if possible. The car feels like it has alot more power left on the table, even if it's all in the top end, which I care most about.
Thanks for reading guys!
- Casey
Another possible reason for the knock is that the clutch on the a/c compressor exploded a few weeks ago and has since been letting me know about it.
fueling or just taking the narowbands' word for it?
Because headers make them lie their little asses off.
The description sounds like false trimming at the
the bottom of it.
the bottom of it.
I want to get a w/b, and have read about wiring it to the EGR pigtail to log on HPT without the Advanced I/O edition. Is this possible with a '98 (have EGR deleted with plug taped up and dangling). The Kooks y-pipe has bungs already in it for rear O2's, and would probably be a great spot for a WB on one side.
When you say false trimming, you mean that the O2's are bullshitting the PCM into dumping fuel on the bottom? The LTFT's are max'd out at times on the bottom with it still reading lean and smelling like a gasoline spill. It also surges up and down trying to catch the swing on startup. I can tap the gas to level it off, but it goes WAY low if I don't at times. I don't really beleive it did this untill I put the new headers in, the old ones were coated Pacesetters.
2) What "reoccuring TPS" problem? Code
3) Knock sensors "maxed" out? How much timing being pulled and at what rpm?
4) The 99+up calibrations for the knock sensors are much more reasonable -compare
5) Get a wideband
6) Actually do 5
nick
nick
5) Get a wideband
6) Actually do 5
I've read numerous posts about the TPS problem, I can't remember the exact code, but it was either "Intermittant high voltage" or "intermittant low voltage". I did the TPS reset, but it's still doing it.
I would clear all DTC codes and do a run. About at the 1/8 mile, the car would feel like it picked up 20hp and the SES light would come on, then the power would fall back off. After the run, the scan showed 4* of KR untill the point where the SES light came on, where it dropped to 0, then came back up again.
I'll check out the KS settings, do you happen to remember which table it was?
I'm definatly going to pick up a WB.
There was one 02 car that has a similar VE to mine and a stock 98 though.
Here's the one from my tune as it sits.
...and here's the one from another car, 2002 with H/C
