Voltage is crazy
Old Nov 8, 2006 | 06:45 PM
navymitch12's Avatar
Default Voltage is crazy
What could cause my gauges to not be reading the correct to the point where my car/ecu seems to "reboot" while i am driving. The voltage that i am reading off the battery posts, the + pos over by the fuses, and the cig lighter are all 14.7......so i am thinking that the ECU is not getting the correct amount of power. Is the only source for ecu power the Generator L-Circut? I am not throwing any codes at all. Any thoughts?
Old Nov 9, 2006 | 04:50 AM
ttt
anyone?
Old Nov 9, 2006 | 09:33 AM
jimmyblue's Avatar
Moderator
Sounds like a loose connection, intermittent, in
either IGN or the ground strapping. Some GND
braids from block to sheet metal that can be
worked loose, crust up etc. Back of driver's
head is one that's hard to see. Might be simplest
to just unhook the battery, remove / wire brush /
retighten every post and sheet metal stud you
can find, B+ / IGN / GND.
Old Nov 10, 2006 | 09:09 AM
....thanks for bringing the fresh mind to this one....i totally forgot to check the 2 grounds on the back of the driver head. fixed it right up! thanks!
Old Nov 10, 2006 | 10:11 AM
steveo346's Avatar
HAHA HAD THE SAME ISSURE WITH MY CAR ....STUPID GROUND STRAPS
Old Nov 13, 2006 | 12:44 PM
TheDogofWar's Avatar
What is "Driver Head" ? my bat voltage is is fine but my gauge and EFILive are only seeing 11v. Battery tested fine and I already replaced the alternator.
Old Nov 13, 2006 | 06:17 PM
drivers side head
Old Nov 14, 2006 | 08:48 AM
drivers side head
LMAO, yeah I just realized it this morning, yesterday was a loooong day.
