Why does everyone ask me if I have a chip?
I can't even count how many times I've been asked if my car has a chip and I always say "no, the pcm was dynotuned with ls1 edit." Then the next thing I hear is "Oh, well you should get a chip." And I've never gotten an inquiry like this from another ls1 driver. As far as I know, we don't have a chip that can be replaced. Is this just because of the typical ricer mentality that pervades the automotive world nowadays or am I missing something.
a chip is for ROM (read only memory) ecm's form early computer control cars. all newer cars have programmable memory where you can tune the pcm, or re flash it
In older cars, at least part of the data used by the engine control computer was stored in one or more removable memory “chips”. The data could be modified by replacing the chips. The ECC in newer cars uses a type of memory called “flash” memory that can be reprogrammed without physically replacing anything. Some highly intelligent racers do not know this.
That's what I thought. Thanks for the responses
Hahaha I think I'll try that from now on.
Originally Posted by SSpdDmon
Tell 'em you have a chip next to your headlight fluid resivoir. They'll leave you alone...
Kleeborp the Moderator™
Originally Posted by brad8266
tell the tards to just **** off, there is no chip for us.
Originally Posted by MeentSS02
You've gotta do something better than that...that's just mean. If they ask the question, just look at them and make a very loud, obnoxious noise. From there on out, every time they mention the word "chip", even if they are talking about Doritos, make the same sound. That should condition them...and if that doesn't work, just pull a Cesar Millan on them by tackling them to the ground until they submit (he's the Dog Whisperer in case you don't watch South Park or the National Geographic channel).
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by SmokeySS
No waiii man you must get tehh chipz!
http://cgi.ebay.com/ebaymotors/MAC-C...QQcmdZViewItem
I can't count how many times i've been making changes in hp tuners at the track and has people ask if I have a chip. I try showing them how I can edit whatever I want. After all that some still comment "you should get a chip", "my cousin/brother/dad ect has a chip in his camaro and it hauls ***.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
EEPROM: Electrically Erasable Programmable Read Only Memory. "Flash" refers to the ability reprogram the prom numerous times whereas the legacy proms were "BURNT" meaning they were more like a one-shot. There was no going back with them. Your only alternative was to remove the chip and install one that had upgraded data 'burnt" onto it.
