Can someone crarify hptuners "credits" for me
I have been reading and I guess I am not getting it.
I am planning on getting the Professional version for $649.
You get 8 credits, correct?
I read this statement - you use 6 credits for the first vehicle, which leaves you with 2 credits.
I also read this statement - you can tune 4 vehicles
I paraphrased, so can some clear this up for me. The whole "single license" or "unlimited" situations.
I had LS1edit split between 3 people along time ago.
Thanks, James.
Thanks, James.
Yes, you get 8 credits total upon inital purchase. Each VIN locked LS1 platform will use up two credits, or if you want to license one complete model/year LS1 platform it will only be 6 credits (you get an upfront discount vs. buying credits for each individual VIN). In the first example, one VIN locked license (2 credits used), you can use the remainder 6 credits to license three more VIN locked LS1 platforms, so you have four total VIN Locked licenses on your cable. In the second scenario (one model/year license), this leaves you 2 credits to use for a single VIN locked license or enhancement (1-Bar MAF, RTT, etc ...). If your friends also have 2002 model F-Bodies, then the single model/year license will work better for you, it leaves you with 2 credits to use as you see fit, plus you would be able to tune any other F-body that is a 2002. Clear?
Originally Posted by Dr. Jeckel
If I run an LM1 base kit, can I run a gauge mounted in the car and still be able to transfer the LM1 between cars. Does anyone do this with some kind of quick connect?
Thanks.
Thanks.
