Air/Fuel Question
Paul
You cannot use narrowband sensors to tune...they are only accurate at stoich...I've seen 850mv=11.8:1 actual wideband verified in my GTP so you can't go by what the stock sensors say.
Paul
Paul
After that, you will need your tuning software to mod the PCM settings.
http://www.hptuners.com/forum/showthread.php?t=9919
bill is a very knowledgeable guy when it comes to HPT , and he is the go to guy when it comes to getting your car tuned!
bill is a very knowledgeable guy when it comes to HPT , and he is the go to guy when it comes to getting your car tuned!933 can be rich or lean, but will be RICHER than 14.7:1
I know that narrow bands are only accurate at stoich.. However is this true that if they reach 930+ they will be richer than 14.7? And will Not be leaner than 14.7?
The reason that I ask is that my wideband has been reading 18-20 afr with 5psi of boost. Seemed to me like I would have blown the motor with this but I havent even gotten any knock. I keep upping my PE but it still reads very very lean. I assumed something was wrong with my wideband... My narrowbands are reading from 940 to 980 and I have gone from running 75% IDC to 130 IDC with my 50# injectors.. Just seems to me that it must be going rich and the wideband is messed up. I just installed a new wideband but have not have time to test it. .
For gasoline lambda=1 @ 14.7:1 a/f ratio. Lambda = current a/f divided by stoichiometric a/f. So, 13:1 would be 13/14.7 = 0.88 lambda. Make sense? Egninerrs use it because we are often targeting 14.7:1 a/f ratio and lambda gives us a measure of how far away from that we are.
The slope of the binary sensor's output varies with temperature. The hotter it gets, the more aggressive the slope, but it always crosses .450v at lambda=1 (14.7 a/f for gasoline). This slope shift is why it's not possible to accurately determine anything other than "richer than stoic" or leaner than stoic" from them. Even this requires that the be at least warm enough for the slope to register significantly with the PCM. (Hence warmup times before going closed loop!)
