Clynlinder air mass WOT
On the Main spark table (cylinder airmass vs engine speed) what cylinder vs engine rpm combination does your car grab its timing from?
The reason I ask is because I thought that you would alter the cells in the .56-1.20 cylinder mass too 3200-8000rpm, but instead I found that it grabs timing from 0.08-0.24 cylinder mass too 2200 rpm and up.
ok, well if you had both tables set to the same degrees, what cylinder airmass vs rpm does the pcm grab the wot timing from?
Or maybe I should ask, does the cylinder airmass drop as rpm increases durning wot conditons
well in that case cly air mass would drop as rpm increases. Peak torque = peak efficency.
Still unanswered , where do you guys alter your wide open throttle timing tables? what section of the advanced table?
there is no wide open only timing table. airmass changes with temps/altitude/pressure, thus depending on how good conditions are, it will change, that's why the timing table is large, so no matter what the airmass ends up as, you can account for it and give it proper timing
Great explanation,
so depending on temps , altitude and pressure (atmosphere) you could be tuning one section of the timing table one day in Denver on the dyno, and then another section for say Arizona given the same rpm.
Mine has hit as high as .80 on the table before, but at peak torque it mostly is in the .76 range. Thats on a exhaust/intake only 5.3L. It gradually increases and then flattens out in the .72-.76 range around 4000 rpm, after peak torque around 4600 rpms, it falls back off to around .68. Is that more of what you were asking?
I am hitting mostly 27-29* at and past peak torque. I have found that dipping the timing at peak torque actually lowers gram/cyl in my truck. In your car, a good value to shoot for would be 24-25* at peak hp.
