truck will not go into PE help
I'm not sure what happened but my truck will not go into PE mode.(according to my wideband o2's. I cant fiqure out whats causing this. It was running fine before I started fine tuning the transmission settings. If anyone could look at my tune, I sure would appreciate it.
Thanks,
Jason
2006 chevy silverado 5.3L HPtuners
Thanks,
Jason
How are you verifying that it is not going into PE mode? Are you logging the Commanded AFR or PE Enabled mode? Just by going off of the wideband doesn't mean much wether it is commanding PE mode or not. If someone has not already, I will take a look at it when I get home from work.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
9 Second Club/LS1TECH Sponsor
I haven't looked at your file but many of the trucks I have dealt with over the years use a PE delay timer. Set that to 0 and you will get instant PE when you floor it.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic1124_1.gif)
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
LS1TECH Sponsor
I dont see any timers under the pe tab.
All I see is:
PE ENABLE
map.............15kpa
map hyst..........6kpa
delay RPM.........1500
TPS ENABLE
hot
cold
hot select 284
POWER ENRCMNT
ratio vs rpm..........1.3-1.4.......(extra PE just till I figure whats wrong)
ect adder..........0
iat adder..........0
enrichment rate .......2
any ideas??
All I see is:
PE ENABLE
TPS ENABLE
hot
cold
hot select 284
POWER ENRCMNT
any ideas??
The delay timer is not available yet, to us HPTuner users.
Hopefully soon. ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Also, do you have a log showing what is going on? You would need to log Commanded AFR and Wideband AFR.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
LS1 Tech Veteran
I have a 2000 K2500 Yukon XL with an LQ4. When I first started working with the factory tune, I was shocked to see that it never went into power enrichment. Then, I learned that the delay timers were all set to something rediculous like 60 seconds. When I set them to zero, PE became enabled and I could do PE Tuning. Later, I did a total reflash of my operating system and went to a 2001 or 2002 OS so that I got rid of the back up VE table so that I could set up speed density properly. Then I reflashed again and went to a custom OS so that I could tailor the AFR progressively from stoic to about 13.0:1 at WOT.
The PE delay timer is definately an issue with the trucks.
All my best,
Steve
All my best,
Steve
I wonder if I need to update my version of hptuners or something??
I have looked everwhere and can't seem to find PE torque enable. It doesnt even show up by searching the help files.
any ideas?
any ideas?
Thank you so much. that must be what is holding back PE.
The torque enable and hyst do not show up under my PE tab, everything else does. I will be looking into an HPT update asap. I am using 2.0.17.0
I may need to look at my software settings from when I installed the software. I remember there being some choices between "beginer"-"advanced" user etc...
before I started messing w/ my transmission settings, I could see an obvious AFR change on my WB guage. It would jump from 14.7 to 12.8-13.0 whenever I would mat the pedal.
does anyone have any ideas on why, with my software version, some of the PE setting do not appear under the PE tab?
Thanks again
Jason
Thanks again
Jason
I think it is the time delay parameter keeping it out of PE. The software I use on trucks has the time delay parameter available for me to edit and evey truck I've seen that won't go into PE at WOT, setting the Time Delay to 0 has fixed it. You will even see that Torque parameter set at 100 on some car calibrations with HPT.
