VE Cell Question
Or would I be better off tweaking the inj flow rate table to compensate for the boost factor?
I have a Aero regulator ref'd to boost & a KB BAP with a 2 BAR ref driving my Racetronix pump to try to hold the pressure up. It drops a little at hi rpms but so far I can't seem to get the a/f to stay in the 11s up hi. So I was wondering how hi I can tweak the PE table. Or is that the wrong approach?
I know, I really should go with 2-3 BAR HPT. I had issues the 1st time I tried SD tuning, but MS showed me it can be tuned. But I haven't done it yet.
of what takes it to grams, is done behind the curtain. Not
that it matters to the result I think.
With the manifold referenced regulator is the fuel pressure still
fading up top, and can you see the upstream pressure as well
as rail and manifold? If you have to command crazy PE numbers
to get the "right answer" somebody's falling down somewhere.
You might also want to see the injector duty cycle as the last
link of that chain. And be sure some sort of misfire issue (even
as simple as over-gapped plugs) isn't just hoaxing the wideband
with unburnt air, might be firing trouble at that high a boost?
I think surveying points along the fuel delivery path, for pressure,
is where I'd start though. PE failing to make a difference kind of
says something's bound up.
Excellent Jimmy! My sentiment exactly. I had similar issues up top until I did the Autometer Fuel Pressure Sensor mod on the end of the rail. I used the EGR power and input, rewriting the Calculated EGR PID to utilize the FPS. I logged batt volts and FPS noticed the batt volts dropping like a rock and the FP following suit at WOT. I theorized that the original 98 alternator was letting me down. Now at WOT, the alt falls offline and the batt has to be up to snuff to carry the load. Mine was definitely not. I rebuilt the alt and upgraded it to a 140 amp o/p and, bingo problem went away. Autozone's alt checker said my bad alt was good to go, after taking it apart I found one of the six diodes bad on the rectifier that the Autozone bench checker didn't catch. Lots of things going on "behind the curtain" in all or any sofware package. About the display units, either way is fine by me, the only concern I have or had as a "newb" with the % of theoretical maximum was that I thought that logically 100% was 100% and going beyond it was meaningless. I struggled with lean conditions and messed with the PE table to make up for things. My stupid mistake. I am now OLSD w/ the RR acting in conjunction with my LC-1 as a fuel trim feedback ckt, only full wideband vice NBO2. So for anybody else just starting out, if you are using the %theoretical maximum display units then that's all it is...theory. That is why you can have ~300% figures.
Thanks Bill, not being all that familiar with HPT I hooked up my Road Runner on a friend's vehicle who was having fueling up top issues. We made some great progress with the RR and at the end of the day we wanted to extrapolate the work we did with the RR in EFI Live to his PCM. I am not licensed to his PCM and I was trying to figure out the least painful way to "export" the work (He uses HPT). The first obstacle was the fact that I had my VE setttings in grams/cyl and he had %theory... I couldn't figure out how to change the VE display settings in HPT so I changed them in EFI Live. Thus, my question in this thread. I thought it might just be me not being all that familiar with the HPT software.
We still had to hand sribe the work...I bet Marcin being the Excel ninja he is would know how to cut, copy, and paste such a thing...Hint, hint.
After having done the FPS mod I highly recommend everybody do it.
remember that the pressure you measure with the autometer fuel pressure sensor you get only the static portion of the total pressure. the pressure driving the injectors is a sum of static and dynamic pressure. the dynamic pressure is mostly related on the speed of fuel (read: RPM)
so that drop of pressure you're seeing is only a part of a story. if your voltage is constant, and the fuel pump is big enough to keep up with the injectors, i bet you the drop is directly proportional to the rpm^2.
the only sucky part about this is that all my december writeups are wrong, because i wasn't aware of this little bernoulli's principle until a pknowless brough it up...damn phd's
