O2 Sim is just a diode?
Old Apr 14, 2007 | 07:33 AM
lovin myls1's Avatar
Default O2 Sim is just a diode?
Read an interesting post from 2006,where a guy said to put a particular diode in line with wires from O2 sensor to fool PCM, leaving the heater circuit intact.So the sim disconnects the heater also but must just be a diode or resistor,right ?
Old Apr 14, 2007 | 11:26 AM
Blacker's Avatar
Not that simple The O2 Sim uses a 555 timer with 4 resistors, 2 capacitors and 2 LED's. With parts from Radio Shack, they are ~$15 to make. A far cry from $50 each. A friend of mine made them for his Supra and they work like a champ.
Old Apr 14, 2007 | 12:29 PM
Ok,can you tell though,if you left the O2 installed with the heater circuit still running,would the diode alone work?
Old Apr 14, 2007 | 12:38 PM
Blacker's Avatar
What exactly are you trying to accomplish with just a diode?
Old Apr 14, 2007 | 12:48 PM
To fool the PCM into thinking the cat is still there and working A-OK
Old Apr 14, 2007 | 01:23 PM
Boodyrider's Avatar
No, that will not work
Old Apr 14, 2007 | 02:45 PM
OK,Thanks.After reading this old thread I found in a search,I thought I'd ask.I linked the thread in case any of you might find it interesting.
https://ls1tech.com/forums/showthread.php?t=550150&referrerid=63909
Old Apr 14, 2007 | 02:49 PM
https://ls1tech.com/forums/showthrea...ferrerid=63909
This one works!
