SD tuning when IAT is integrated into MAF?
Brett
{C2901}MAF High Frequency Fail to 1Hz
{C2903}MAF High Frequency Fail Limit to 1
{C2904}MAF Low Frequency Fail to 13,000Hz
{C2906}MAF Low Frequency Fail Limit to 1
That's what they're called in EFI Live. HPT may have slightly different names. The limits are basically the number of times the MAF can fail the test for going above the High or below the Low. By setting them to 1, it should fail immediately.
also, if you have an auto, make sure that the trans dtcs are set to not allow max line pressure when you have a MAF failure.
The other table you set higher is the calculated airflow table. If not it will throw a 1514 code.
Isn't that why you copy the high octane to the low octane table so you are dealing with the same timing curve? What method do you recommend for tuning then? I tried leaving the maf hooked up and adjusting the VE tables to match but at idle and low cruise I was already at 85 and up in the cells. That is def not correct.
Brett
