LS1 Edit...... PE vs. RPM?
BTW, finally got the timing curve right on! Thankyou NoGo for your input....
Now how about some info. from the Edit guys here? Is this info available for a newb to Edit like me?
Pleeeeassse!
Any input is appreciated.
Me, I don't have heads but do have a TR224/.561/112 CAM, REV Valvetrain, ASP Pullies and FLP LTHeaders ( there's more but you get the idea )
I have my PE vs. RPM setup - 97% of stock 0-5200, 95% of stock 5600-7000. It was setup MAF 105, PE 95%, using the GTO/Holden High and Low Octane tables with 5600-7200 .72 grams down = 30. I changed to 107% of stock MAF ( ltrims were 1 to -2, wanted them just a bit lower. The 95% PE was getting some knock just between 4000 and 5200 so I eased up just a bit to 97% below that range.
Once I can actually get on a dyno that has o2s, I can dial that in better then just using EFI and my ear.
RPMs 0 400 800 1200 1600 2000 2400 2800 3200 3600 4000 4400 4800 5200 5600 6000 6400 6800 7200
Multiplier 1.1783 1.1783 1.1783 1.1812 1.1812 1.1812 1.1812 1.1812 1.1812 1.2035 1.2035 1.2035 1.2035 1.2132 1.2074 1.2074 1.2074 1.2074 1.2074
Oh well, I will figure it out....just looking for a "trend" with diff. setups. I am going to base line it at 13.2 across the rpm band on the dyno and follow the inverse of timing curve. Makes sense to starve it at lower timing advance. My goal is to be rich as possible at high rpm and timing and still make the power.
Normally I would post the results.... oh well.
kick_*ss what does your WOT timing look like? Thanks again for the info.
If so here it is. Now this I actually had to research the mess out of.
%TPS 45 45 45 45 23 23 23 19 19 19 19 19 19 19 19 19 19 19 19
good stuff there for a new guy to edit. Once you get the maf straight get you timing close and tune your fuel with pe vs rpm.Recheck your timing and your done.
What is your load range.. .500 to .600?
Thanks for the info!
H82BBad: Thanks for the insight to rechecking the timing...but would you not just tune the fuel in with no knock and call it good?
