HOLY CRAP...look what fixed several problems
Maybe this will help someone else. Several pain in the *** issues...GONE. And I see people here with idling and surging issues all the time. I say "HOLY CRAP" because I had no warnings, no SES lights, nothing on scan tools.
#1)
In the past few months I've had surging issues on start-up. I would have to start my engine and not drive it for about 2 minutes while the surging stopped and idled smooth. Then I could get in and drive and everything was perfect. But if I drove somewhere about 15 minutes away and turned the car off, did my business and came out and started it again, same ****, it would do the same thing but only for about 1 minute, then I could drive normally. Also, sometimes I would come to a traffic light to stop and it would start surging while stopped for a little bit. Also, if I turned the A/C on while idling, stopped, it also went nuts for a little bit.
#2)
Shifting from "PARK" to 'REVERSE" was violent, a big bang into gear. Also, from "PARK" or "REVERSE" or "NUETRAL"...into "DRIVE". Big bangs. It sucked.
#3)
I had a scan a few months ago and it showed my Throttle position sensor (TPS) was bad. ***NOTE*** Thats all the scan showed, nothing else. AND never ever an SES light, I just had my friend scan it to see if something showed up
I could unplug it and the engine would run the same. So I replaced it and the problems were still there. Oh well.
#4)
My fuel consumption went though the roof too, starting about 3-4 months ago too. This problem may be solved to, I haven't had a chance to check yet as I just put the new MAF on.
So, a couple days ago I went by Advance Auto for a scan because my SES came on while driving. It showed P1133, "Fuel Air Metering". I bought a new stock OEM MAF.
Came home and before I put it on, for ***** and giggles, while the car was still running, unplugged my MAF. Nothing happened at all, the car just sat idling normal. I left it unplugged and pulled out of my parking lot and went for a short drive....The engine ran NORMAL.
I learned yesterday that a bad MAF causes the PCM to go to a SD tune. Also, when the TPS fails the PCM will go to a SD tune. So you may never know if they fail, I didn't, no SES light. I also had a Z06 MAF on my car for 5 years. The stock one from Advance works perfectly. Engine runs great. Went for a 20 minute drive just now and its all back to normal. Cars is still a nasty bitch and runs perfect.
No surging.
No banging into gear.
I can start it, tuen it off, let it sit for a few minutes and it starts up perferctly and idles right where it always has, immediately, A/C blasting or A/C off.
I'm pretty sure the gas mileage will be better now too. We'll see.
Now before anyone says it, I've had the dealership scan my car about 5 times looking for these problems and my friend who has an OBDII scan it at least 5 times, all over the past 3-4 months. NEVER has anyone showed a bad MAF. NEVER did I get an SES light for the TPS. I changed the TPS back then because I unplugged it and the car still ran perfectly.
So for whats its worth, and since now we know for a fact that an SES light will not come on if a MAF fails (at least in my 1998 WS6), and we also now know that a car with a failed MAF can run perfectly fine when the PCM goes to SD tune.............if you have surging or idling problems, just unplug the MAF and/or TPS at different times to see if this is your gremlin. If the engine keeps idling the same and you can drive it and its the same, there ya go.
What an easy fix to a highly aggravating problems. Too bad my SES light didn't come on earlier and have it show up on a scan, this would have been fixed months ago.
#1)
#2)
#3)
#4)
No surging.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
well my cars rpm's will drop to about 400-500-rpms some times when i put it in gear[reverse or drive]then the rpm's come back up and its fine so could that be the problem?
im going to the track tomorrow and when i get up tomorrow ill try cleaning the maf to see if it helps.
it hasent been doing it for that long so maybe thats the problem. i also have had a small surge at idle that i can get rid of no mater what i try[seafomed the car tryed different plugs at diff gaps and no luck]
Like Billiumss said, The problem is that so many people just dont know how to properly use a scan tool. It is UNREAL how many use a scanner just for a code reader, they see no codes and they dont know how to interpret scan data.
And like he also said, a bad maf, or a dirty maf is usually very easy to spot with scan data and if not a scope check will most likely show it.
Originally Posted by 5_02ls1
all your maf needed was cleaned its actually a common problem talked to death ....and if your meter went bad there would be a code
What code is for the failed meter?
Originally Posted by Billiumss
Good right up but if you would have scanned for the MAF freq you would have found the issue much earlier. If the MAF doesn't output a frequency, then it's junk.
Glad you got it fixed though!
LS1 based cars can run with or with out a MAF. Thats why we have a lot of VE resolution. Most boosted guys and hardcore big cam drag racers don't use the MAF and go Speed Density mode.
You go to a dealer, first thing he does is connect the scan tool, if no codes pop up, he stops. If he would have checked the MAF freq on the Tech 2, he would have found the problem.
LS1Tech Sponsor
what should the MAF frequency be, or how do you know if it's not right??
__________________
06MonteSS / DiabLew Tune
![](https://ls1tech.com/forums/signaturepics/sigpic53380_2.gif)
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Kleeborp the Moderator™
Originally Posted by Quickin
But if I unplug the MAF with the car running and the car is still drivable and drives normal, isn't that a 100% sure thing that the MAF is doing nothing?
Depends on the car and mods.
On average it should be around 2,500-3,000 Hz at idle and should go up smoothly as rpm increases. Using the awesome scan tool that HPT has, it's real easy to look at the MAF out put in either freq or lb/min, in table form or graph form
Depending on what year LS1 it is, unplugging the MAF doesn't automatically make it shift hard, it did/does on 98 cars but on the 2001-2002 cars it doesn't, I've done it many times when I tune the VE table, A4 cars drives fine.
LS1Tech Sponsor
__________________
Where is our MAP sensor located? I see the big piece that the brake booster line attaches to, but what is the other sensor that is attached to that, the one with the white colored square on it. Thanks.
![](http://www.ls1howto.com/howto/geniii/intakemanifold//IMAGE007.jpg)
It's the one where the 3 pin connector module plugs onto the back of the intake. In that pic it has a white sticker on it.
After driving for two days with the new MAF on. My converter is locking up much more crisp and solid. Very much a noticable difference. I've posted in the "Tranny" section a few times asking whats up with my lock-up not being "crisp".
Its kind of ridiculous how many things one single part can change about our cars, but whatever.
