help please!!!!
Old Jun 10, 2007 | 10:58 AM
camross998's Avatar
Default help please!!!!
ok while i was doing my LT install I broke the ECT sensor. I when try to find another one but the only one i found was the 2 prong one so i put it in so i could stop leaking coolant but the coolant gauge dont work so the car is in Open Loop so can i tune it out for the time being till i get the ect sensor so the car can go into open loop mode and will i have any probs
Old Jun 10, 2007 | 11:15 AM
98Z28CobraKiller's Avatar
Restricted User
Yes and no. You would have to change quit a few tables to get it "tuned out". There are several ways to skin this cat.
Old Jun 10, 2007 | 11:50 AM
camross998's Avatar
can sumone help me i got efi live want to put the car in open loop till i replace ect sensor will it hurt the car if i changed the value in b4205 to zero
Old Jun 10, 2007 | 12:00 PM
P Mack's Avatar
The car is in open loop mode.
Old Jun 10, 2007 | 12:05 PM
camross998's Avatar
yea it is i think not sure but the pcm is not getting the temp so i think it in pcm in close loop mode
Old Jun 10, 2007 | 12:08 PM
P Mack's Avatar
With the ect sensor unplugged the pcm is probably reading coolant temp as -32F or whatever, which means it will stay in open loop because it never reaches the closed loop enable temp.
Old Jun 10, 2007 | 12:10 PM
wait4me's Avatar
the third leg of the sensor just goes to your gauge cluster temp. the other one goes to ground and the other goes to the Computer.
WHY dont you just go to Napa and pick up one for a 1998 camaro, they should have them in stock.
Old Jun 10, 2007 | 12:16 PM
camross998's Avatar
jessy i try went to the dealer napa peep boys auto zone discount bentt you name it none of them had it and i need it for tonite when i race i just need a quick fix till this week when i order it.
Old Jun 10, 2007 | 12:50 PM
camross998's Avatar
sumbody on here tell me to jump the plug on the harnes with a resistor but I'm not sure how to jump it or where or how to make a resistor can sum one help me please need to race tonite
Old Jun 10, 2007 | 01:27 PM
camross998's Avatar
Anybody can help me
Old Jun 10, 2007 | 05:36 PM
camross998's Avatar
can anybody tell me something
Old Jun 10, 2007 | 05:41 PM
wait4me's Avatar
You know, your fans wont turn on without that sensor. Just wait a few days, get one at the dealer, then you can race all you want. It isnt worth blowing up an engine for a night of not waiting.
I am really suprised that no one has one in stock!
Old Jun 11, 2007 | 07:28 AM
Restricted User
The 98 sensor is not common. I tried to get one once and it took 3 days.
Sorry that I didn't get the PMs until just now. As I said, the ECT is referenced by alot of tables. I'm not sure that by dropping the CL entry point you will get the car to run properly. I had suggested to him that as a quick fix, try to determine how many ohms resistance it will take to get it to read in the 190-200 temp range. This would simulate operating temp for a quick TEMPORARY fix. The other thing that you could do is put in the 99+ sensor and wire it to the plug. Your gage wont read but atleast the PCM would know what temperature the car is at.
Old Jun 11, 2007 | 11:49 AM
camross998's Avatar
oh ok thanks dude i just when to napa and it coming tommorow problem fixed but because of this though i got more of a understanding for tuning and how the the sensor work which aid me in learning how to tune my car thank again
