Paging HVAC Gurus, HELP!
I'm still interested in any comments on performing this operation, though. I'm wondering if a 12 volt portable air compressor could be used to pull the required vacuum?
You need to pull a vacuum of at least 28 inHg for at least 30 minutes to pull the moisture out of the system. After pulling a vacuum for 30 minutes close all gauges and make sure the system holds the vacuum for at least 10 minutes. If the system holds hook a Freon source to the middle manifold line, purge the line of air, and then start to charge the system. Do not overcharge the system.
http://www.harborfreight.com/cpi/cta...temnumber=3952
I got it on sale for $10
The system should be charged immediately after the vacuum procedure is completed. The tech that pulls the vacuum should also do the charge.
I paid about $4 each for two 12 oz cans; that seemed to be the perfect amount for my '93 Fbody. http://www.harborfreight.com/cpi/cta...temnumber=3952
Many thanks to all that responded to this thread, knowledge is good!
The Details: I wound up building an adapter hose to connect the input of my shop compressor into my gage manifold. I was able to get 21"Hg this way, which is a little short of what I wanted, but the system is working well. Next time I'll get a real vacuum pump. It held the vacuum without any perceptible drop for 15 minutes, so I added 2ozs of PAK oil, two cans of R134a and ended up with 33 psi on the low side and 165 psi on the high side at an ambient of 80*F. The shop manual called out 25psi/178psi @ 85*F.
