LC1 tuning with HP tuners
Any help will be greatly appreciated. Thanks!
I explained how to configure in Hp Tuners here... As far as hooking it up you're gonna actually tap into the ground wire on the stock O2 to ground it and then hook the narrow band output to the signal wire... Just look up the diagram for the stock o2 and you'll know what I'm talking about.. Then you're gonna hook the Wideband output up to your wideband gauge and to the EIO input port... That way you can read it on your computer.. It sounds a lot harder than it is.. Goodluck..
https://ls1tech.com/forums/pcm-diagnostics-tuning/808574-pcm-voltage-egr-sensor.html
basically i used the rear 02 sensor harness for logging the wideband. left the front nb02 in place. in hptuner set up a user defined pid for reading the egr signal and another user defined pid for the afr error%. it is pretty well explained on the hptuner site.
Assuming you have the LC1 already hooked up and working with a gauge.
On the green little plug off the side of the HP tuners module I hooked the tan analog 2 wire from the LC1 controler into slot 1 (This is the top slot closest to the top of the module)
Then on pin 5 I ran a ground wire directly to the source of the grounds on the LC1
In HP Tuners Scanner, go into the table display screen and right click on EIO Input 1 (On the botom) Hit Insert. Locate LC1 and double click. Make sure you save the changes.
Then go into your histogram screen and hit the configure button. Choose the histogram you want to use. Click on the PID, Then Aux Input, then wideband O2, then LC1. Set your plots to 20.0= High, 14.7= Mid, 10.0= Low
You MUST set each table..ie...histogram, table display, charts...They will NOT pull over to eachother
Once you've configured the scanner, save the changes
Now move onto the "LM Programmer" to set the analog output 2. First make sure the serial connector is plugged in correctly.
Open the software and click on analog 2. Click on "Factory Defaults", then hit program.
Your all done. This will configure HPT and the LC! together.. I'm sure there are 1000 different ways to skin this cat. All I know, is that I just did it this EXACT way, and it works perfectly.
To verify, while your scanning, look at the A/F in the table display. Also open the logworks program (You need the serial cable connected) The logworks program is seeing what the sensor is actually seeing. HPT and logworks will be within .1-.2 of eachother..
I hope this is what you were looking for. Although my instruction are all jibberjabber, hopefully you can make out what I was saying...
Jeff
free bump i wanna kno too
