Where is all my HP
309hp/320tq stock with 800 miles.
340hp/351tq w FLP's,Corsa
362hp/359tq with TR220 cam
382hp/370tq with mild ported Heads
372hp/365tq with 12 bolt(3.73's)
390hp/385tq with TR224 Cam,ported TB and tuning.
412hp/397tq with edit tuning
All at the same dyno,I've done over 60 pulls there.
Now today I went with 4.11's gears installed,ported LS6 Heads(11.2-1 comp,2.02/1.60 valves)Denny's steel nitrous DS and tuned it in with Edit with 28 degree's total timing and A/F tuned to 13-1 across the board with 0 knock and ended up with 408hp/391tq.I did start with 390hp/375tq and A/F at 12-1.
The temp was around 95 degrees and engine temp was 180-190 each run.I really think there should be highers #'s for my setup??? Could I be missing something??
Another H/C car was pushing 405hp after tuning that should be with the 420-430hp club.This is on a dynojet dyno.Could the correction factor be off?
My M6 car traps at 117mph in the 1/4 with 3700lb race weight if that helps.
in the rear end, for sure. Rotating mass
contribution to horsepower loss depends on
how fast you run up through the RPM; if you
have the option of making this happen slower
then you could get another reading and get
to an extrapolated constant-RPM horsepower
(not that that would be a very interesting
thing, race-wise, but it would give you
some idea of how much the heavier DS etc.
might have played into the back-sliding).
Any "correction factor" is a balled-up set
of assumptions and somebody else's data. The
less your particulars resemble that, the more
out-of-line the correction will be. I think
the way gears let you run up the load drum
speed differently relative to engine RPM
probably gets into that, big time.
