SLP de-resistor MAF table
Old Dec 18, 2007 | 12:43 AM
sdbrown84's Avatar
Default SLP de-resistor MAF table
Hey guys,
I need the MAF tables for a 85mm SLP with the resistor removed. I assume that it is the same as the Z06's but I just want to be sure with those who really know.
I have this site but I just want to be sure it is the same before I begin tuning on the car: http://www.ls1howto.com/index.php?article=25
Thanks guys.
Old Dec 18, 2007 | 07:23 AM
kenp's Avatar
Those are the stock tables for the 85 mm maf. Easy thing is to use your tuning software to get the tune off a site & copy & paste the appropriate values into your table.
Old Dec 18, 2007 | 08:18 AM
Frost's Avatar
Use your wideband and make it up based on % error from your current table.
Old Dec 18, 2007 | 09:13 AM
jimmyblue's Avatar
Moderator
You will get reasonable results from either a truck MAF or a Z06
MAF table, slight differences and one or the other may fit your
intake tract's particulars. The truck is slightly higher airflow hence
richer resulting mixture. You can fine tune from whichever base
is closest to right.
File Type: zip
Old Dec 18, 2007 | 09:14 AM
YellowToy/A's Avatar
If you dont use a wideband and tune u will have the wrong A/F ratio.
Old Dec 18, 2007 | 10:17 AM
NicD's Avatar
7 Second Club
Since you have an f-body I would start with the truck 85mm MAF tables instead of the Z06 ones, it will get you closer quicker.
Old Dec 18, 2007 | 10:41 AM
jimmyblue's Avatar
Moderator
The truck was closer for me, stock H/C, but after cam and LS2
heads the Z06 was closer and the truck table too rich. Just try
them and see what works.
Old Dec 18, 2007 | 11:51 AM
02 BLK WS6's Avatar
Do yourself a favor and throw the SLP MAF in the trash
Old Dec 19, 2007 | 08:53 AM
Eurospec2's Avatar
SLP maf with resistor removed = stock truck MAF, why would he have to throw it in the trash?
