Rich at idle after cam
Check your O2's and see if they are white'ish color=lean. Or Plugs.
I fixed my rich problem with a twist of the idle screw. I got my IAC's down to 50 from 120. Didn't have to do anything in EDIT except to raise the idle to 775
Nic00Z28M6 on this board progressively scaled his with good results, so I tried that and it seems to be working well so far: 1200 rpm = 80%, 800 rpm =70%, and 400 rpm =60%. [/qoute]
Good advice, I think I might play around with that a bit.
1) The VE table solution. Described by CAL. I'm not a big fan of this solution for idle problems. The VE table determines your base PW for your injector fueling. If it is too small, you will get the hesitation as descibed above. The VE solution will fix your problem, but there are better solutions in my opinion.
2) Raise your idle. Idling a large cam too low will generate many drivability problems. Your cam should idle between 800 and 1000 rpm.
3) Partial open loop solution. You can directly control your fueling by forcing your car to open loop for idle operation.
Cams and aftermarket exhausts have a tendecy to confuse O2 sensors. Meaning, they can cause your car to unecessarily dump fuel. Your LTerms may say that every thing is fine, but common sense (rich gas smell, smoke) should tell you its not.
To kick your car to open loop partially, change all points in the WOT Hot and Cold tables for all RPM up to 1600 to zero. Now, you can directly use your PE table (at these RPM points) to control fueling.
This solution works fine, but can cause surging if your PE table has too much of a step change (ie 1.5 at 1600 rpm to 1.24 at 2000 rpm)
4) Full Open Loop. Personally, I can't stand oxygen sensors. On a near stock car, they are great. They improve your fuel economy, make you emmissions compliant, and provide a reliable a/f ratio. On highly modded cars, they can be a different story. Many of the modifications that we do to our cars confuse the oxygen sensors. So instead of providing reliable a/f ratios and good gas mileage they acutally do just the opposite. They have a tendency to drag your a/f ratio either too rich or too lean (usually too rich) because of false readings. You don't find O2 sensors on cars that do not have to meet federal emmissions regulations (like the middle east). Our cars run just fine without oxygen sensors, and from a tuners perspective, usually better.
To kick your car to full open loop change all values in the Open Loop Enable Temp table to 300. To control vehicle fueling hook up a wideband and use the Injector Flow Rate table to dial in an a/f ratio of ~14:1.
Good Luck,
Kevin
I tried to do #3, Partial Open Loop. However scaling the lower rpm ranges in the PE vs RPM table has almost no effect on the idle AFR, even after I set TPS to WOT at 0 from 0-1200rpm. Any ideas? My idle is really rich (11.5:1) and I want it to be around 13:1.
Sorry bomax, I'm no help . . . we'll just have to wait for NoGo on this one. How do you know your AFR is that? I don't think you can trust your O2 readings at idle.
