Need help, poor acceleration
I have visually checked the throttle blade and it is going wide open and very quickly.
The throttle position angle only shows 88% at full throttle even though the throttle position shows 100%. The long term fuel trim on bank 1 and 2 are about - 16%. The short trim from O2 sensor 2 on both banks is 99%. Should I be showing anything at all if the 2nd O2 sensors have been edited out?
The short term fuel trim is about -0.8 on both banks.
I have logged some operation, so ask for any parameter, and I will look them up.
I am used to these engines just starting right up with no problems, but this thing feels like a 4 cylinder engine!
I pulled the MAF off my truck and tried it, to assure that the MAF was not bad, and it did not improve it.
Thanks, John McGraw
Any advice would be truly appreciated.
Regards, John McGraw
The O2 sensors track each other very well, and the pattern is very similar to my daily driver pickup truck.
One glaring difference that I see between my daily driver and my conversion, is that the calculated engine load at idle on my truck is about 2%, while my conversion runs about 21%. Does this make any difference in operation?
Thanks, John McGraw
Being that this is an ETC, there is no IAC motor. So, the throttle must be open in order to run properly.
What controller are you running? Where did you get it? You might be running into a torque limit on the setup. I know some of the ealry GTO stuff was really soft as to lengthen the drivetrain components life.
This is a 05 GTO motor with the factory computer. Once the car gets moving, it goes pretty good, but off-the-line performance is pitiful. It is in a 65 Corvette with a tube frame, a 4L65E trans and a C4 Corvette Dana 44 rear end, with 3.45 gears. I have a 59 corvette with a stock LS1, and it would run away and hide form this car. My 4.8 liter chevy truck pulls harder off the line than this car does! It only weighs in at about 2900 lbs, so it ought to scream.
I take it that a good tuner should be able to wake this car up? The computer was programed by Speartech, and the harness is from them as well. No Cats, and a large, free flowing exhaust system. The drive train should be bullet proof.
How did the torque limiting get it's input to soften it up? Could the skewed calcualted engine load at idle have an effect? I presume that it is displaying a high calcualted engine load at idle because it does not have an input for barometric pressure, and that is used to calcualte the engine load. The Barometric pressure reads 99 at all times.
Thanks, John McGraw
Yes I can see the vehicle speed on Autotap. What should I be looking for? does the torque management kill the timing to control torque? I have not been able to find out how the torque management control works. I contacted John at Speartech , and he said that he doubted it was torque management, and suggested the problem was fuel supply, but I checked the fuel pressure , and it was a steady 60 psi regardless of engine speed or throttle position.
Once I know what to trend the vehicle speed against, I will make another couple of pulls with the laptop graphing the parameters.
Thanks, John McGraw
Unfortunately, I only have the basic Autotap and not the extended codes. I can not see any parameters that pertain to traction control. If you get a chance, I would appreciate you stopping by with your tool.
The O2 sensor pattern is pretty normal, and the two sensors pretty much track each other. The fuel trims, both short term and long term, are modulating well and never get anywhere near minimum or maximum value.
Thanks, John McGraw
I graphed the pedal position, commanded throttle position and the actual throttle position as well as both O2 sensors and Engine RPM.
The throttle is commanding correctly and the actual throttle position goes wide open as well. The O2 sensors fall off the face of the earth as soon as you nail the throttle! They hover down around the 0 mv level until the throttle position is dropped back, or the engine speed builds. The fuel pressure at the rail is rock steady the whole time. It would appear that either the program is not enriching the mixture when the throttle is opened, or the injectors are really clogged. I guess I will go to the auto parts store tonight and get some cleaner, but it is hard for me to believe that they could be clogged enough to cause this problem, but still have normal fuel trim values at all times except under high throttle position. What do y'all think?
Sounds like you're on the right track. Shouldnt be too hard to figure it out from here.
