02 Tables Set To 250
or above 350mV. If you tweak them down you are
effectively leaning out closed loop some. How much,
nobody knows. Too much, and you may end up unstable
(if the O2 bottoming voltage is higher than threshold,
no crossings will be found and trims will swing wide).
If the wideband center is leaner than 14.7 in closed
loop this would be one likely reason why, or the desire
to have it leaner may be why it's got those values.
This is a compensation for the sensor not reading correctly because it is farther away.
