LS1 Edit / MAF Tuning vs MAF Translater
I after 18 months of reading and watching the threads on the LS1 Edit emails I have learned how tuning your WOT fuel throught the use of the MAF is not as good as by other means, I believe, do to timing issues mainly. So how is it that the MAF-T is able or is the MAF-T going to run into the same issues as Edit?
Re: LS1 Edit / MAF Tuning vs MAF Translater
Thanta what I am getting at. I have Edit, but a friend has desided to go with the MAF T instead. I am trying to show him the light and that the MAF T is not going to work as well as doing it the right way.
I just want to know if the MAF-T has the same negative effect on timing as when you adjust your MAF through edit for more fuel? Sorry Brian if you thought I was chatting about you, but it's not you.
I pretty much figured that you weren't talking about me, I just had to give you a hard time about it.
By the way though, the car sounds bad a$$!
