LC-1 wideband question?
I didn't hook it up to my labtop the 1st time around. I reread the instructions and it says to hook up the DB-9 cable to the out connector than launch LM programmer. But the hook up on the cable is female and my labtop is female too. So I can't do that.
I know the gauge is not reading right because the air/fuel ratio looked good when we dynoed it and my tuner hasn't messed with the tune. Just put it from SD to mass air since the dyno.
Thanks for the help,
Jimmy
EDIT: just read you put it after the y-pipe, do you have cats? I only see STS in your sig so I'm going to assume you don't... if you do, I would put the sensor pre cat. If you are !Cats then disregard.
-J
) and the sensor was in a constant state of calibration as a result! I fixed up the wiring and programmed the sensor to update @ the 1/6th speed and everything is AOK now.-Eagle
Good luck!
Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2) can be connected
to the analog inputs of other devices such as data loggers and ECUs. If either one or both of
these wires are not being used isolate and tape the wire(s) out of the way. The default analog
outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR. This is a
simulated narrowband signal. Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39
AFR. Note: The LC-1’s heater ground and system ground wires should be grounded at
the analog input’s ground. Refer to chapter 2.2 for recommended wiring schematics
I was also wondering how most of you guys wire the or sensor in the the ignition circuit so that it turns on with the car. I deal mostly with mechanicals not wiring so much so this install is actually quite challenging.
As for the analog output you should be able to search to find the answer to that. It basically works like you say.
