Problems with LT headers
Old Jun 23, 2008 | 08:12 AM
juanjuan07's Avatar
Default Problems with LT headers
I have FLowtech lt headers and the first week the ses light turned ON, codes, P0300,1153,1133. I have read threads here and tried what people said and nothing has work, i changed my o2 sensors for bosh 13111 and the codes came on anyways. What should i do, turn them off or change the fuel injectors table by 15%??? Becuase my concern is that people havent decide what will happen if i turn the codes off, some said that it will go to open loop, others say it wont go to open loop.
Need the answer of of person that really know about this.
Thanks
Old Jun 23, 2008 | 08:16 AM
juanjuan07's Avatar
Also, i went to a dyno for some tunning, and the sensors function the first minutes and they were switching perfectly and all that, then they just flat out. But they were reading right.
Old Jun 23, 2008 | 11:47 AM
9000th01ss's Avatar
You need to find out what is causing the misfire code.
You either have an engine problem causing a misfire, dumping fuel and fouling the O2's OR you have bad O2's giving the engine false readings and causing a misfire.
If you just installed headers I'd check the spark plugs and wires. I've replied to three people here in the past two weeks with random misfire/backfire problems after header installation. One was a cracked spark plug and the other two had wires burned against the headers.
Old Jun 23, 2008 | 12:00 PM
juanjuan07's Avatar
Ok, when i chaged the sensors, the misfire havent come again, but the other two 1153 and 1133 came again. Can i turn the codes off or should i take out the headers and put back the manifolds.
My concern is that i dont want to run on open loop because the mpg will be afected.
Old Jun 23, 2008 | 12:29 PM
9000th01ss's Avatar
Originally Posted by juanjuan07
but the other two 1153 and 1133 came again. Can i turn the codes off .....My concern is that i dont want to run on open loop because the mpg will be afected.
I don't think it'll run in OL because of that but it won't get the correct signal from the O2's. Having non functional O2's will cause bad gas mileage. And poor operation.
1153 and 1133 are insufficient switching codes. From my experience thats a problem with the sensors or connections.
I don't know what you've got there as far as other mods to the engine but I have my original O2's connected to my LT's with extensions and they switch fine.
Old Jun 23, 2008 | 01:05 PM
Greg Norris's Avatar
did you switch the o2s when you put the LTs on or did you run your old ones for a while? the reason i ask is because people have commented on how the inside coating of the LTs wears off a little and jacks up the o2 sensors.
Old Jun 23, 2008 | 03:26 PM
juanjuan07's Avatar
I changed the O2 snesors this week and they switch fine for few minutes, then they went flat. So i cant turn them off because i will have bad mpg??? So the best thing will be to take the LT out right??
Old Jun 23, 2008 | 03:27 PM
juanjuan07's Avatar
Any one here have a webpage were they show me the complete wiring of the sensors so that i can verify it???
Old Jun 23, 2008 | 07:41 PM
9000th01ss's Avatar
I would exchange the O2's for new ones. It sounds like you got a bad set.
Then with HPTuners on, start scanning before you start the car. See what the O2's do.
You should not need to put stock manifolds back on. You need front O2's to run the engine, so you can't turn them off.
Is there something special about this engine or car it's in? Anything else been done to it, parts? Tune?
Old Jun 23, 2008 | 07:56 PM
juanjuan07's Avatar
Yes i have SLP cold air intake, comp cams XR265HR (212/218 .522/.529 114), LT Headers and tuned with efilive. The sensors are brand new. But what is weird is that when i started the car (it was cold) the sensors switch perfectly as soon as i step on the gas a few time in the dyno, the sensors flat out (when the engine reach normal temp). So what is weird is that it doesnt look like if they wasnt receiving enough heat. They read right but does no switch. i have check cables and all and nothing is touching the engine and all cables are right. I check for the grounds, but what i dink is that if i have a bad ground they wouldnt function from start.
Please i need help because i want the car to run great.
Also what i thought it was to set the PCM to ignore dose codes.
Old Jun 24, 2008 | 11:27 AM
ZL1Killa's Avatar
just turn the damn things off, they are pointless. and its not the sensors or connections. its from my experience from 4years of exhaust flow over the 02
I have had mine off for 4 years and my car is fine and runs fine
Old Jun 24, 2008 | 01:49 PM
9000th01ss's Avatar
Had your what off? codes turned off or sensors tuned out and removed?
And thats all you did was remove the front O2's and tune the codes out, no further tuning for doing this?
Old Jun 24, 2008 | 04:17 PM
juanjuan07's Avatar
What you say is to set those codes off, but that the sensors will continue to do their job, to set the AFR.
That makes sense because i bought both sensor new from GM, and the codes again, then bought the Corvettes 13111 sensors and the same, i have waste a lot of money in damm sensors.
Will the car run in open loop and will the mpg will be affected? I will get the car tuned again the same day the guy will turn the codes off.
And another question. If the car runs in open loop the only thing it changes is the AFR??? Because if a have a wideband i can check that right??
Old Jun 24, 2008 | 08:21 PM
ZL1Killa's Avatar
turn the 1133 and 1153 codes off.
sensors are still in and work fine.
I did not say I removed anything.
when you turn these codes off this DOES NOT mean the 02s are turned off, JUST THOSE CODES ARE OFF
Old Jun 24, 2008 | 09:50 PM
9000th01ss's Avatar
Don't blame me for your aneurysm.
Old Jun 24, 2008 | 10:49 PM
juanjuan07's Avatar
What are you meaning when you tell that "dont blame me for your aneurysm"?
Old Jun 24, 2008 | 10:58 PM
OUTLAWZ RACING's Avatar
The problem is heat the 02 are not staying hot enough. I have fix the problem by moving the 02 bung closer to the collector. I also had a budy just wrap his headers and the code went away.
Old Jun 24, 2008 | 11:07 PM
9000th01ss's Avatar
Talking to the other guy that seems mad at me.
Old Jun 25, 2008 | 11:18 AM
juanjuan07's Avatar
But wait, what you are telling me is to move them even farther from the engine, closer to the header end???
To wrap the headers completely i will have to take them out, and that is a pain.
Old Jun 25, 2008 | 11:31 AM
ZL1Killa's Avatar
not mad at ya, my words didn't apparently come out the way i was thinking and others didn't know what i was thinking.
