VE table
Old Jul 20, 2008 | 09:15 PM
Peppershaker's Avatar
Question VE table
Have car tuned SD. Need to know which VE table is being used; the primary or the secondary. Or may be even better can you tell me under what conditions is each primary or secondary VE table used. Another words which one needs to be changed to affect tune. Thanks Bill
Old Jul 20, 2008 | 09:24 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
It might help if you posted what kind of car (and year).
Old Jul 20, 2008 | 10:37 PM
foff667's Avatar
LS1TECH Sponsor
Typically when the maf fails it will fail to the secondary VE table when the vehicles pcm is equipped with a secondary VE table.
Old Jul 20, 2008 | 10:42 PM
stevegrizzle's Avatar
What program are you using?
Old Jul 21, 2008 | 03:24 PM
The car is a 1998 Z-28. Have the Maf turned off and removed from the car. Tuning with HP tuners. Have the car running pretty well. But just want to tweek it alittle more. Was always copying primary to secondary VE table. Was just wondering which Table car is running off of. Would save some time making changes if I knew which one affects tune.
Old Jul 21, 2008 | 03:30 PM
foff667's Avatar
LS1TECH Sponsor
Secondary VE
Old Jul 21, 2008 | 03:36 PM
Frost's Avatar
...and it's using the low octane table as well.
Old Jul 21, 2008 | 04:01 PM
Thumbs up
Thanks for the help. Much appreciated
