160* T-stat?
Old Aug 6, 2008 | 12:18 AM
273sunsetZ's Avatar
Default 160* T-stat?
I've got hptuners and can't figure out what needs to be changed for the car to run cooler. I put a 160 in it and it still runs at 205ish. So i was then told to adjust when the fans kicked on so i did and it still runs at 205. is their a sensor i have to replace somewhere or something, or is their something i can still use in hptuners to change it...?
Old Aug 6, 2008 | 12:32 AM
twpetry's Avatar
what did you adjust the fan temps to?
Old Aug 6, 2008 | 12:33 AM
apex1's Avatar
Car will only run so cool. A 160F t-stat will not make your car run at 160F.
Old Aug 6, 2008 | 12:44 AM
FC_LQ4's Avatar
what kind of radiator/ fan setup do you have?
Old Aug 6, 2008 | 01:48 AM
vjo90rs8's Avatar
If you are looking at the stock temp gauge....DON'T!!!!!
99-02 FBody's basically have a "dummy gauge", once it gets close to the 210* point it doesn't move much. I set my fans with HPTuners and when scanning I get a consistent 185* while cruising and at idle even though the temp gauge says ~200*+.
Here are the fan settings what most people use for a 160* stat
Fan 1 ON: 184
Fan 1 OFF: 175
Fan 2 ON: 194
Fan 2 OFF: 185
Hope this helps!
Old Aug 6, 2008 | 12:05 PM
273sunsetZ's Avatar
Fan 1 ON: 184
Fan 1 OFF: 175
Fan 2 ON: 194
Fan 2 OFF: 185
Hope this helps!
Thanks, here is what i had mine set too...
Fan 1 ON: 180
Fan 1 OFF: 174
Fan 2 ON: 199
Fan 2 OFF: 190
Old Aug 6, 2008 | 12:07 PM
273sunsetZ's Avatar
I know this.... I was just asking if their was something else i needed to adj. to get the guage off of 205...
Old Aug 6, 2008 | 12:26 PM
jimmyblue's Avatar
Moderator
Forget the gauge. Read the ECT using the scan tool.
The thermostat has nothing to do with ECT except
when you are coasting at high road speed in winter.
The rest of the time it is airflow, airflow, airflow.
Fans and radiator. Both undersized even for stock
and trying to take cooling air off hot pavement is
sheer genius.
Old Aug 6, 2008 | 12:46 PM
ZL1Killa's Avatar
the gauge in the car is CRAP. read your scantool and I bet your engine will not get to 195 or higher depending on fan settings
