Project V6 Firebird
Old 06-03-2013, 10:32 PM
  #301
WarShrike's Avatar
Got the BLS projectors finished after some fine tuning and me fixing one of my screwups. My camera doesn't know WTF to do in auto with the lights like this, and I didn't have time to fart around with the settings...
Old 06-14-2013, 10:29 PM
  #302
WarShrike's Avatar
While waiting on other things, I replaced a few items. Both the ICM and coils were looking worse for wear and the car had started to stumble a bit after idling in the heat. Figured with my next step in the build, I'd just eliminate that issue right now with new ignition equipment.
Installed a new ICM and GTP/SSEI coils. The SSEI coils are ACDELCO Part # D576.
Also replaced my aging O2 sensors with some Denso units (THANKS SDPC!) as I started getting a code thrown for inefficiency issues. Come to find out, my band clamps had worked loose a little and was letting air into the stream. Will have to make a note to myself to tighten them during each oil change interval.
Took it for a drive, but couldn't get spirited as there were literally police everywhere I looked! I can sense a bit smoother increase in the revs, but we'll see when I take it for a drive tomorrow and will do some tuning/datalogging on top of that.
Old 07-02-2013, 11:54 PM
  #303
chrysler kid's Avatar
Nice progress. What clutch and flywheel are you using with the t56
Still running the stock 2:72 gears in the rear? Can you even use sixth gear I would almost go higher than 4:10s for the v6
Old 07-03-2013, 02:01 AM
  #304
AndersonsSS01's Avatar
Very awesome build, excited to see this thing once the turbo build is finished. I had a 98 v6 m5 as my first car and loved it. Had all kinds of ambitions of doing something like this until it got totaled (not my fault btw and a very long story behind that ordeal). But then came the lt1 and now finally an ls car. Love the fact that you don 't care how fast it is but just enjoy the experience of doing it all your self and having something different than most other 4th gen guys.
Old 07-03-2013, 05:32 AM
  #305
WarShrike's Avatar
Muahaha, this thing came stock with 3.42s and a posi. Runs 45mph in 6th without lugging. Gotta love the GTO T56 gear ratios. 4.10s would almost make the first 2 gears useless on this one
Stock V6 clutch and flywheel (Same spline as LS1 clutches), using a 1/2" slave spacer.
Old 07-06-2013, 10:27 PM
  #306
WarShrike's Avatar
Went to Coffee & Cars today with my daughter in tow. She had fun, just a day past 1 year old and looking to be a car nut
Old 08-10-2013, 08:02 PM
  #307
IrishRifles's Avatar
What that cost you to have cleaned up?
Old 08-12-2013, 12:23 PM
  #308
WarShrike's Avatar
To have what cleaned up?
Old 08-17-2013, 10:49 PM
  #309
WarShrike's Avatar
Umm. It's big?
120lb/hr injector
More stuff to follow in the next few weeks but then I will probably go radio silent when school starts.
Old 08-27-2013, 09:33 PM
  #310
WarShrike's Avatar
UMI Performance 3-point Subframe connectors are installed, still need to paint the weld points to protect them.
Here's a pic of the T-56 installed, you can see the adapter plate (barely) and the mods done to the cross member to accommodate said adapter plate.
Old 08-27-2013, 11:44 PM
  #311
JLFIII's Avatar
glad to see an update to this...how much did the sub frames run you?
Old 08-28-2013, 08:05 AM
  #312
WarShrike's Avatar
$368 after shipping and taxes at SDPC. Friggin taxes
Old 08-31-2013, 11:54 PM
  #313
WarShrike's Avatar
I'd say the subframe connectors did exactly what they needed to!
I had to do spark plugs today and spray paint the welds while I was under there. I don't feel safe trying to drive a manual trans car up on ramps and then put it on the stands so I just jack the car up on each side to get the front tire high enough to set it on the ramp.
I can now lift one entire side of the car and have both tires off the ground. The chassis could flex enough that the rear tire would still be on the ground at this height.
Old 09-09-2013, 06:49 PM
  #314
WarShrike's Avatar
Got parts coming in. Boost block and turbo should be here soon. Have to assemble, will do that after some machine work to handle the powah and keep it sealed at ~25 psi and high rpm.
Old 10-19-2013, 09:37 PM
  #315
WarShrike's Avatar
Well, this came in. Got a few other things with it. Up next is the heads/cam/intake package from WOT-Tech, then a flywheel so I can send it to the shop and get the whole rotating assembly balanced to help make reliable/efficient power even up top.
Old 11-25-2013, 09:31 PM
  #316
WarShrike's Avatar
Well, I'm doing research on the next step after my top end package is done. Flywheel and Clutch to handle the power at max effort.
Monster is the only US based company that seemed to be up to the challenge, but I'd have to send a flywheel to them first before they could give me the go ahead. I effectively got e-mails from other venders that said "NOPE!"
In the mean time, I decided to look in Australia for V6 friendly apps for the T-5 equipped Holdens. I think I found a jackpot, but it's gonna be costly.
Gonna have to tag this NSFW now...
This was in an e-mail from NPC just now, they recommended the 10.5" dual plate kit. I asked for pricing and pics if possible.
Here's the Coyote V8 clutch/flywheel combo, the flywheel will be different but the clutch will be very similar. Good to 800rwhp and ~$1800USD + Freight from Australia. MF-ING Ouch. Power doesn't exactly come cheap, folks. Anyway, I figured I'd have to be staring down a clutch/flywheel combo that would come out as a sizeable chunk of cash.
Anyway, PR0N!
This was on their website, single plate, 6 button ceramic clutch kit:
Old 11-26-2013, 10:48 AM
  #317
Stinger22009's Avatar
Nice.
Old 11-26-2013, 10:50 AM
  #318
What size turbocharger you going with?
Old 11-26-2013, 10:54 AM
  #319
WarShrike's Avatar
Garrett T67 with a .82 AR
Old 12-06-2013, 08:50 PM
  #320
WarShrike's Avatar
Just a little cold outside today...
Quick Reply: Project V6 Firebird
