Banging/ thumping coming thru floor?
Old 10-23-2011, 12:36 AM
mud.man.rj's Avatar
Default Banging/ thumping coming thru floor?
Just took the 2000 Trans Am out for it's second ride tonight and did a burnout (auto Trans) and major thumping noise from drivers side under acceleration, no noise when driving normal, just under load, can't get in my garage as working on a 63 T.Bird resto, but looked underneath and all looks good, was wondering if it is the barrunning from trans to the diff, bushings or related. Anyone have this problem, I will look at it soon and figure it out for sure, but wanted a heads up if possable. Thanks. It is a WS6 if that matters.
Old 10-23-2011, 07:52 AM
j99fbody's Avatar
sounds like a broken trans mount
Old 10-23-2011, 08:20 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Yep, I'd have to agree!
Old 10-23-2011, 10:27 PM
mud.man.rj's Avatar
Thanks, trans mount makes a lot of sense, will find out when I can use my own garage again.
Old 10-24-2011, 09:11 AM
Shane's Avatar
Is it all stock? If not, some header setups can cause exactly what you're describing...
Old 10-24-2011, 09:44 AM
MuscleCarNut711's Avatar
When my trans mount went it made loud noise when the trans made the 1-2 shift under any kind of acceleration.
Old 10-27-2011, 07:03 AM
MidnightMafia's Avatar
like my bbk's I have same problem, gonna put in poly motor / trans mounts and see if it helps (it still has the stock ones from the factory so I'm sure they are prolly getting worn out anyway)
Old 11-02-2011, 07:41 PM
Raleigh TA's Avatar
My Y-Pipe spanks me whenever I hit the pedal hard. There are fixes described in another post if that is the issue. Poly mounts may help, but there is a hanger that is supposed to be more definite fix.
Old 11-02-2011, 08:03 PM
Coy
Coy's Avatar
The hangar "fix" is a bandaid. Replace your motor/trans mounts and you will be fine.
Old 11-03-2011, 07:05 AM
That's the plan, hope it works
Old 11-05-2011, 03:08 PM
Cooldude5231's Avatar
mine did the same thing.
come to find out my trans mount was broke in half
Old 11-05-2011, 11:47 PM
was it a PITA to replace?
Old 11-05-2011, 11:55 PM
mud.man.rj's Avatar
I guess I just have to finish the other project in garage, kick it out and start looking hard. I am going to drive the Hell out of it so may change more than it needs anyway.
Old 11-06-2011, 09:39 AM
Coy
Coy's Avatar
Not at all. Install University has a write-up on changing it out. It takes about 30 minutes including the time to Jack the car up and eat a sandwich.
Old 11-06-2011, 11:54 AM
nope.
took me like 20 minutes.
only problem i had was the cross member bolts wanted to cross thread.
Old 01-19-2012, 03:39 PM
thompsontransam's Avatar
My T/A does the same thing? Could it possibly be the torque arm?
Old 01-19-2012, 04:03 PM
Ocala93TA's Avatar
I would say 80% of the time its the tranny mount .
Old 01-19-2012, 08:27 PM
mud.man.rj's Avatar
Went thru complete system and trans mount was partly broke but couldn.t see it until I unbolted it and had a good look.
Quick Reply: Banging/ thumping coming thru floor?
