98 firebird v6 engine bogging and shakes
so cars been running fine got it 2months ago now when i went to go start it today the engine sounded like it was choking u can hear it through the exhaust too and its just puttering. The rpms were bouncin up and down oil pressure was a little higher than usual and i got an oil change today and when i go to pull off it hesitates to move and once im in a certain rpm it starts to bogg out and by the way it does it in each gear when im bout hlf way down on the throttle in each gear and when im driving and the rpms strt bouncin like crazy then it kicks bak does fine then it goes into the next gear fine and does it agian and when i gas it all the way down it jus dnt wanna go jus shakes if anyone has an idea please let me kno
possibly clogged cat. go ahead and give it a tune up to see if that clears anything up, not like it would hurt to do so anyways. I'm sure you have a check engine light on with the way you've described it's running so get ahold of a scanner and check that out. Do basic spark/fuel check, and make sure your egr valve isn't stuck open.
i was thinking the same thing cuz you can hear it choking more underneath the car and i jus started it this morning for a cold start n it was doing fine but once it strted to warm up it started to do it agian an i noticed too now my temp gauge isnt telln me its warming up n iv already replaced a waterpump bout a month ago
Sounds like you did the cardinal sin of buying the car and not doing routine maintenance once you bought it.
Spark plugs (NGK TR55's are great for the 3.8), wires, fuel filter and oil change are usually the best bet. Fix the spark issue and make sure your cat isn't clogged.
I had 2 V-6 Firebirds before I got my current car and both gave me problems with the plugs and wires. You need to change the spark plugs and wires and your cylinder misfire will go away. On one occation a bad plug wire caused one of the 3 coils in the coil pack to blow. When the coil blew the car would drive fine except under a load or exceleration, then it would buck like you describe.
So change the plugs and wires and if the problem continues, test the coils.
I did all of my plugs from up top, but I have a 2000 model. 2000 and newer have the tubular manifolds. 1999 and earlier have the log manifolds that almost make it mandatory to change it from under the car. Unless your car has aftermarket headers of course, which makes the plug change easy.
I'd recommend getting a new fuel filter if he let that thing sit for a year.
well i replaced all spark plugs and wires and the problem still continued so i replaced all my ignition coils and that was the problem jus the coil and iv got a question im lookin at an upper delphi intake manifold for my v6 would u suggest something else or would that be good enough
I don't know about Delphi intake manifolds.
But if you haven't already tossed out the coils you replaced there was probably only one that was bad, the other 2 should still be good. They are inter-changable and I found out which one by moving the coils and seeing which cylinders the problem moved to.
You may be able to have the coils tested at an auto shop or parts store, then you can keep the good two in reserve.
