Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
Old 06-04-2009 | 10:48 AM
  #501
oddwraith's Avatar
Originally Posted by oddwraith
Hmmmm. low voltage huh? I wonder if thats whats causing a slight "pulse" in my lights and the cause of my Pass. side light not popping up? It turns on but sometimes (when auto activated by low light) does not pop up!
Anyone have any ideas? I cleaned up as many grounds as I could and replaced the batt. Also the alt seems fine (not sure about the volt. regulator though?) and I have replaced the positive side-post battery cable bolt. I noticed when the pass. side light doesn't pop up (only when auto activated for some reason, at night) it is in fact turned on, just not "popped"! Anyone?
Old 06-04-2009 | 11:33 AM
  #502
JasonWW's Avatar
If it's pulsing it could be low voltage or else the bulb is cracked and is dim. When the engine is idling the voltage is on the low side and may pulse a little. Normally headlight bulbs are bright enough that we can't see the pulse. If it's old and yellow though, the pulse may be visable.
Also, since you have a light sensor installed (US Firebirds don't, but I converted mine to Canada spec) there may be an issue in the DRL brain in the dash behind the radio to the upper right.
Try putting a digital multimeter on the battery when the headlight bulb is pulsing and see if the voltage is also pulsing. If it is, then maybe the voltage regulator in the alternator is close to going out. A really low idle speed can cause voltage pulsing too, so make sure that's not the cause.
If there is any binding between the headlight cover and the hood, that could cause it to not pop up.
Old 06-13-2009 | 05:59 PM
  #503
JC70SS's Avatar
Alright guys here is one for you. Put brass gears in. They worked great for 2 months. Now the other day only 1 light would come up. I played with the switch and the first day they would both come up. Now just one comes up. I unplugged the harnesses and they will both go up and down for about a half day then sometime neither one or just one?? This is so frustrating, but I know both motors are fine. Any ideas? Headlight switch or module?
Old 06-13-2009 | 07:19 PM
  #504
428 78T/A's Avatar
Happened to me yesterday. I turned the switch off leaving the lights up. Tapped on the motor with a 3/8 ratchet, worked fine after that. Although I know theres something still not right.
Old 06-13-2009 | 09:11 PM
  #505
JC70SS's Avatar
Well I pulled really hard on the headlight switch...both went up and down. So I started to pull the dash and headlight switchout to replace the switch. Went to dinner, came back now the right one goes up and not the left one. When I left both went up(didn't even drive the car)!!!! WTF!!!!!!!!!!!!
Old 06-20-2009 | 10:29 AM
  #506
transamLs1's Avatar
this is a long thread so i didnt read what anyone else has said but i changed my plastic gears to copper and that worked for a while but then i got tired of it and just jammed the headlights up lol!
Old 06-20-2009 | 01:44 PM
  #507
JasonWW's Avatar
I'm pretty sure it was brass.
If you read the last few pages you'll see that O'reilly (I think) now carries replacement motors much cheaper than a GM dealer.
Old 06-28-2009 | 05:43 PM
  #508
Mid's Avatar
Mid
Originally Posted by JasonWW
It definetly a voltage problem. Check the connection between the wires and the headlight plug. Those plugs get corroded. I replaced both my low beam plugs with some insulated female spade connectors. That fixed it right up. Polarity isn't an issue for the bulb, so don't worry about that.
Ah good call. How do I replace this?
Old 06-28-2009 | 09:53 PM
  #509
Danny2tek's Avatar
just cut the harness off and use some spade type connectors.
Old 06-29-2009 | 12:37 AM
  #510
Jersey Mike's Avatar
Someone save me some reading please...
..."Mind of It's Own" Syndrome. One headlight only flips up when it feels like.
It takes multiple ON/OFFs before both headlights come up...Why?
Old 06-29-2009 | 12:50 AM
  #511
LCplmarine98's Avatar
The gear is probably stripped or close to it. Its like starting a car with a chip in the flywheel, if you get right on that chip it will make a horrible noise and not start, so you have to try again or move it. Same general concept.
Old 06-29-2009 | 07:53 AM
  #512
Danny2tek's Avatar
Check for corrosion in the harness
Old 06-29-2009 | 09:05 PM
  #513
2000 t/a's Avatar
Question Head lights are being wierd
The head lights on my 2000 trans am are acting wierd when i lock and unlock my doors with my remote they flip up and when i turn my parking lights on they come up and when they go down they sit there buzzing for about 5 seconds or so just seeing if anyone has had this problem or if anyone has any idea of what it could be
Old 06-29-2009 | 09:48 PM
  #514
1995blacktattop's Avatar
headlight motor gear is stripped. very common. you need to figure out which side is doing it and replace the gear.
Old 06-29-2009 | 09:54 PM
  #515
LS1Transhed's Avatar
I literally have this same issue. Except it seems to last more than 5 seconds.. but maybe thats because the sound is so tedious lol. If I remember correctly, switching the plastic gears with brass ones will solve this problem permanent.. if not for a long long long time.
I dont believe there is a sponsor that sells this, so:
http://www.bfranker.badz28.com/headlightfix/
Old 06-29-2009 | 10:06 PM
  #516
crazymofo1986's Avatar
u can also turn the gear and use the other side. search.
Old 06-29-2009 | 10:08 PM
  #517
lemons12's Avatar
man i have never heard of this.. mine has been doing it a long time..
i doubt anyone has ever asked this before...
im stumped...
SEARCH!
Old 06-30-2009 | 11:01 AM
  #518
2000 t/a's Avatar
but why would my head light go up and down when i lock my doors with my remote and when i have my parking lights on
Old 06-30-2009 | 01:14 PM
  #519
lemons12's Avatar
something to do with the resistors or some **** like that...
just do a search, its been discussed over and over... search "head light grind" or something of that sort..
Old 06-30-2009 | 02:46 PM
  #520
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Or just review the sticky at the top of this forum.
Quick Reply: Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
