Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
Old 04-23-2010, 06:30 PM
  #801
WS6_101's Avatar
Anyone have pictures of the LMC housings with HIDs in them? My driver's side low beam is out and am looking to get some new housings with HIDs in them
Old 04-23-2010, 07:26 PM
  #802
Danny2tek's Avatar
I only took one pic with my phone so they look like two giant spot lights . They're not blinding it just looks like that with a phone camera.
Those are with the fogs and the lows
Attached Thumbnails Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE-hid2.jpg   Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE-hid3.jpg
Old 04-23-2010, 07:28 PM
  #803
tmc2k1's Avatar
Oh I believe you. I just wanted to see how badass it looked from the front
Old 04-23-2010, 07:31 PM
  #804
Danny2tek's Avatar
I'll get a better pic with my D60
Old 04-24-2010, 11:02 AM
  #805
WS6_101's Avatar
lol that would help out...is the light output good from inside the car?
Old 04-27-2010, 03:10 PM
  #806
1998Firehawk's Avatar
Default 98-02 Headlight Assembly Arm Bushing
Guys, my headlight motors are fine, but the arm that raises and lowers them has some worn out bushings so my headlight shakes while I'm driving with them in operation. I tried a hardware store and found something close butit's not quite large enough on the outside diameter. Are there any kits for these out there - maybe the 3rd gens, Fieros, or Vette have these same bushings?
Thanks
Old 04-27-2010, 03:42 PM
  #807
teamfbody's Avatar
never had a problem with my lights yet but i will buy the metal ones like everyone else my friend 01 WS6 lights used to do that everytime he would hit the alarm or door lockz
Old 05-03-2010, 04:15 PM
  #808
flamingfirebird7's Avatar
So, My lights had been working fine for about a month, no problems no noises or anything. They went up and down fine. Just the other day I went to turn them on, the drivers side light went up fine, the passenger side light up didn't go up. So I shut them off, Then turned them back on, sure enough they both went up. I drove it for a while, shut them off. I went to turn them on again, sure enough the drivers side went up, while the passenger went down. This time I can't get them to both go up, this is so annoying. When you go to turn them on, both motors turn, why doesn't the passenger side light come up?
Old 05-03-2010, 05:50 PM
  #809
WS6-R's Avatar
Check connector for mold.....mine was molded.
One teeth broken from plug and one cable hanging.
Looks like the mold ate away the wires and mess up the electric current.
Old 05-05-2010, 09:30 PM
  #810
offroadfury6's Avatar
NEW ISSUE:
-So I installed Brent's gears. Lights have been working fine the past 3 weeks. but yesterday, I noticed my driver light was up about half-an-inch. took off the bezel and tried to adjust the metal plate. cut them back off, the lights went totally down then the driver light lifted about half-an-inch...why wouldn't it sit flush, why does it pop up alil now?
-I can also barely pull on it and it will flip up about 2 inches with very light pressure. I can push on it and it will go down from the 2-inch lifted back to the fucked up half-an-inch.
-Anyone had this issue or know a solution?
Old 05-06-2010, 08:24 AM
  #811
Danny2tek's Avatar
odds are your white stopper is missing. look at post #1
Old 05-06-2010, 02:31 PM
  #812
I hope not cause when I had the HL motors out, I made sure I took off the stoppers and turned them to the opposite side.....I'll have to look at it after my pinched knerve heals....if the stopper is gone, can u just wrap the metal stob with pipe tape? or is it too soft and the metal arm just tear straight through it?
my bro-in-law backed his car into the T/A last night, so I'm missing quiote some paint on the rear bumper
Old 05-06-2010, 03:24 PM
  #813
steve000's Avatar
Is there a LMC housings for a 93-97 TA/Firebird or something equivalent. Thanks
Old 05-06-2010, 06:35 PM
  #814
Danny2tek's Avatar
I used electrical tape ( a couple of turns/wraps)
Old 05-08-2010, 12:05 AM
  #815
99'CajunFirehawk157's Avatar
Talking
Added LMC lights today!
FWIW-I like most of you guys have had issues with my motors and after much wasted time with metal gears and such I found the best thing is just bite the bullet and pick up new gm motors thru eBay for under $75/ea, problem solved for at least a few years, longer for me cause my car is parked most nights in the garage. YMMV
PS-I have a used set of Bosch E Code (Ralleylights) low beams just like on Susquehannah's Motorsports website, purchased from them by the prev owner and a set of HID's I will be selling, I bought these used and never installed them after seeing how nice the LMC's were. PM for info.
Attached Thumbnails Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE-img_4186.jpg
Old 05-08-2010, 07:32 AM
  #816
That's MISTER MODERATOR
Paul Bell's Avatar
I know some of you guys are waiting on my install of the Autoloc HID's into my LMC housings and some pics of them. I haven't yet received the HID kits. They said they're waiting on the correct ballists which should be in at the end of May.
Old 05-08-2010, 10:41 PM
  #817
i checked, both stops are there. but now one is chewed up pretty badly. the arm was going past the stopper, so I bent the stopper bar out alil, worked good first 2 turns but now it's still popping up a quater of an inch, I was thinking, maybe put alil black tape over the plastic stopper?
Old 05-09-2010, 12:57 PM
  #818
Danny2tek's Avatar
yes that will work, put a couple of wraps around it
Old 05-09-2010, 10:34 PM
  #819
Well, my passenger head light wasn't going up. Well lucky for me all it was, was the control arm running into a bolt, causing it not to come up.But now all of a sudden my fog lights don't work, they worked fine before. Not even little orange light thats supposed to light up when there on lights up now. What could this be?
Old 05-17-2010, 11:53 PM
  #820
chrysler kid's Avatar
hey guys when is the last time some one ordered a brass gear from the linked site. just want to make sure they are still making them and the link in this first post is still good for ordering
Quick Reply: Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
