Some tire questions
I'm currently restoring my 69 Firebird 350. I was talking w/ my buddies earlier and they mentioned that it would be a good idea to put some really big and "fat" tires on my ride. I personally like the idea but am not sure about the consequences. Does anyone know which are the biggest tires that can be put on a 69 Firebird that is stock? I'm planning to raise the rear a bit to give it a more aggressive look so that should be taken into consideration as well. I was wondering what is considered a nice looking setup. I was thinking 295/60-15 rear and 275/60-15 front or 315-60-15 rear and 275/60-15 front. Also, what negative effects can come from putting too big size tires? I've heard that tires that are too big can just slow u down. Any suggestions are appreciated.
A common misconception: Wide tires DO NOT put more rubber on the road, assuming the same tire pressure. The amount of rubber on the road is dependent on tread design, tire pressure and vehicle weight. For a given weight and tire pressure, any tire will have the same sized rubber "patch" on the road.
I agree that wide tires look good. And you can more easily run lower pressures to increase traction. But these days, with soft-compound drag-radials available, you shouldn't have too much trouble finding a tire, even one that's not ultra-wide, that will hook up your 350.
Yeah I'm looking into some BF Goodrich Drag Radials or some Mickey Thompson's, but I wondered what size was compatible with the stock ride height and if too big of tires would clash w/ the wheel housing while turning and such...
I'm sure you've got some issues on the wheelwells on that car - they look even smaller than the 2nd-gen cars. I've only had 2nd gen and up cars, so I'm not sure what will fit. I'll give you a TTT to see if anyone out there knows what will fit in the wheelwells of a first-gen F-body.
Sorry to ask but I'm new to the site and I'm not up to speed with the forum lingo, what does TTT mean?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Might want to take a look at https://ls1tech.com/acronyms.html
Sorry you're not getting any answers, Musclebird. This might not be the best place to post, since most guys have later model cars.
There are some other boards out there for earlier cars. Here's one:
http://forums.performanceyears.com/6/ubb.x
There's another big one that I can't remember . . .
I currently have 295/50's on 15x10's on the back of mine. They have many miles on there. They work fine, but the car has never done anything but spun them. They wouldn't hook up till 4th gear. As for the big fat tire, I'm trying to go with my 335/30/18's if I can get them to fit.
