Stock G8 GT cam specs?
Here's the reply I got from GM Performance Parts when I asked about the HOLDEN L76 cam specs. I also asked if it was true that the grind was different between the de-activate cylinders and the normal cylinders.
Answer 1 = 200/208......0.472/0.479
Answer 2 = Yes
Re: Holden L76 Stock Cam
AFM cylinders have slightly different grind ( a bit taller) to accomodate additional compliance of AFM parts --intent is lift event equivalence.
1.70 Exhaust Rocker Ratio
1.69 Intake Rocker Ratio
Lift:
@Cam @Valve
Exhaust: 0.282 0.479
Intake: 0.279 0.472
Cam Timing@0.004" Tappet Lift:
Open Close Adv. Duration
Exhaust: 71 BBDC 33 ATDC 284
Intake: 11 BTDC 91 ABDC 282
Cam Timing@0.050" Tappet Lift:
Open Close Duration
Exhaust: 40 BBDC 12 BTDC 208
Intake: 17 ATDC 37 ABDC 200
__________________
Answer 2 = Yes
Lift:
@Cam @Valve
Intake: 0.279 0.472
Open Close Duration
__________________
LS1 Tech Administrator
200/208 .472/.479 116.25LSA, 116.75 intake centerline (based on the valve events posted).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Thanks for the cam info, I just picked up a used L76 pull out last week. Will be doing the DOD delete and cam springs and push rod swap next week. The motor should be stout after mods.
I am going to mate it to a 4L80E and throw it in my Datsun 240Z with a 150 shot!
