3.70s/TrueTrac going in tonight!
The DS axle must have popped out also, then the sidegear spun on it a bit. It's galled. I'm going to do a bit of "touch-up" tonight and get it installed.
![](http://img.photobucket.com/albums/v320/GeorgeInNePa/gall.jpg)
![](http://img.photobucket.com/albums/v320/GeorgeInNePa/gall2.jpg)
![](http://img.photobucket.com/albums/v320/GeorgeInNePa/Comedy/greatsuccess.jpg)
![](http://img.photobucket.com/albums/v320/GeorgeInNePa/G8/axleds.jpg)
The diff ships with some gear oil in it already, but you will need some to top it off. Since I had the factory LSD removed and replace with the TrueTrac, I used a quart and about a 1/4 of standard gear oil.
You will need some blue lock-tite for some of the bolts.
